Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
2-cup won't work
I bought and returned 5 machines until finally I found one that worked. Unfortunately it worked until I descaled it. Right after that it started acting up. Tapping twice the cups would not respond and would make only one cup. A few days later I cleaned the brew unit and emptied the tray and it lost the setting for the shot size. It would only prebrew and stop. When I tried to reprogram the coffee shots and I took my finger off the button at 1 oz the water wouldn't stop running until it filled about 4 oz of water. It took about 8 times of repeating the steps until finally it set at 1 oz. Out of desperation I bought a brand new machine and program it exactly as the old one. While the touch panel works it dispenses the coffee only on one side of the nozzle. I tried enough of these S-series to realize that they are riddled with problems.
You can try descaleing it again ,then go into
the factory reset program and reset it , I had a
similar problem this fixed mine
Posted on Jan 08, 2008
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Will not start descaling
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Found the answer on another fixya post. Seems like about the same product.
http://www.fixya.com/support/t6123164-tassimo_red_light_stays
Apr 17, 2013 | Coffee Makers & Espresso Machines
How to reset descale function on Capresso coffee maker
follow this steps and fix it. God bless you
    • 1 Unplug the coffee machine and remove the cup.
    • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    • 6 Unplug the machine and dump the water into the sink.
    • 7 Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Oct 15, 2012 | Capresso Jura-Impressa C 9 One Touch...
How to descale tefal express boil
I was searching for this solution then I found the manual in a draw so to help anyone else with the same problem the method is:
Descaling should be carried out every 3 months.
Fill the appliance to max. Dispense maximum size cup to a large cup.
Add descaler to the cup then pour back into appliance.
Dispense the mixture in the appliance into the cup and disgard.
Continue until applance is at minimum water level.
Empty the appliance then refill with water and run it through the machine and disgard until its at minimum then empty the appliance again.
It should be ready for use. You can use 1ltr white (and only white) vinegar instead of the descaler and water mixture.
Jan 24, 2012 | General Kitchen Appliances - Others
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    How to descale a breville one cup
    NOTE: Not my instructions i just found something similar.
    According to the instructions for Breville Hot Cup (presumably similar to yours - the adjustable flow one):
    1. Fill it to the max and dispense one cup of water.
    2. Add a citric based descaling product into the cup and stir.
    3. Tip contents into kettle and close lid.
    4. Dispense water from the kettle, discarding the water until it reaches the 'min' mark.
    5. Empty remaining water into sink, rinse out with clean water.
    6. Fill kettle with fresh water and dispense cups of water until it reaches the 'min' mark. Empty the rest into the sink, then refill ready for use.
    Nov 24, 2011 | Breville Coffee Makers & Espresso Machines
    Not enough water making it from holding tank to dispensing cup
    your machine is "Short Cupping"
    It needs to be descaled. Even though the descale light might not be on yet, the descale light only comes on when it is in SERIOUS need of a descaling. You should descale once every 3 months.
    Fill reservoir with distilled white vinegar and leave the machine on for 4 hours (make sure to turn off the auto off option).
    after 4 hours, run the vinegar through the machine until the reservoir is empty. Refill with water and repeat twice. you will notice a difference right when you start running vinegar through.
    Apr 04, 2010 | Keurig Elite B40 Coffee Maker
    It's blinking de-scale side water holder gets r4eally hot water is not coming out properlywhen u press one of the cup size bottons
    This is the time, you need to Descale the machine. The simple procedure is :-
    Unfortunately, in spite of the best-laid plans of mice and men, espresso machines often get clogged by scale, deposits of minerals from hard water. Scale can cause serious damage if untreated. If your espresso machine's water flow has decreased a lot, it's probably because of scale. Fortunately, there is an easy and inexpensive way to descale your espresso machine.
    1. Obtain some citric acid. You can either order this online or find it in the kosher foods section of the supermarket (usually marketed as "sour salt"). Acid solutions dissolve scale, which is made of calcium carbonate. There are special solutions marketed specifically for descaling, but citric acid works just as well and is much cheaper.
    2. Prepare the descaling solution by mixing citric acid with water (I use two tablespoons of acid and a quart of water).
    3. Put the descaling solution in the water tank, turn on the machine, and run water through the steam wand until the cup is filled, to expose the parts to the solution. Turn off the machine, and leave it for 20 minutes so that the solution has time to dissolve scale.
    4. After 20 minutes, run more water
    5. Run solution through the machine every 20 minutes, until the water tank is empty.
    6. Fill the water tank with plain water, and run water through the machine until output water no longer tastes sour. This is important, because excess citric acid does not make coffee taste good.
    Let me know, if need further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Oct 12, 2009 | Keurig Coffee Makers & Espresso Machines
    How do I descale a Krups Dolce Gusto machine?
    _451.jpg_450.jpgSorry about picture quality, fixya only let you upload small file sizes
    Aug 21, 2009 | Coffee Makers & Espresso Machines
    Descaling light on
    Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
    1) turn off the "Auto Off "feature
    2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
    3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
    4. Press the large mug Button
    - let Keurig coffee maker fill mug with vinegar & empty in sink.
    5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
    6. Rinse the water reservoir thoroughly and fill with fresh water.
    7. FINAL STEP RINSE CYCLE
    a) place a ceramic cup on the drip tray
    b) run regular brew cycles WITHOUT using a K-cup.
    c) pour rinse water into sink each time.
    d) repeat brew process until water reservoir is empty.
    d) perform additional rinse cycles if you notice any residual vinegar taste.
    e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
    Otherwise - you're good to go!
    Apr 16, 2008 | Keurig Elite B40 Coffee Maker
    Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
    96 people viewed this question
    Top Saeco Coffee Makers & Espresso Machines Experts
    eyecam
    Marvin
    Marvin
    Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
