Question about Mitsubishi WS-48311 48" Rear Projection Television
No sound Kids played Wii on the tv, now there is no sound with the televsion. DVD's have sound, and the receiver plays from the radio, etc. What could they have touched? Thanks.
  • Clueless1 Dec 26, 2007
    It turned out to be a remote control issue, someone had turned the volume all the way down, when my husband called Mitsubishi he stumbled upon the problem. Cables were all okay. Thanks much for your help!
  • 69 Answers
I suppose you have a surround sound system that is now not functioning? They must have disconnected your audio out cables from your television to your surround sound system. Make sure your main audio out channel on your television is connected to AV1 in on your surround sound system. It is probably an RCA cable (red and white). Then when you play your TV, make sure the audio is set on AV1 for your surround sound system by pressing the function button until AV1 is on the display. Let me know if this helps.
Posted on Dec 26, 2007
How to connect surround sound, tv,wii,dvd
Depends on your TV, surround system, and the provided connections.
The most common with a decent LCD TV is connected all the input devices (DVD, Wii, etc) to the TV via their respective connections. Run the audio from the TV to the receiver via HDMI or SPDIF or other audio out line on your TV. Set TV to output audio through that line always and you are done.
Quality audio receivers will have a panel where you connect everything to it, then connect the TV to it via HDMI. It will play the audio and send the video signal via HDMI in what is called a pass through. This will only be an option on quality, mid to high end audio receivers.
In either case, reading the manual for the receiver will tell you how to do this.
May 14, 2011 | Televison & Video
Kids got wii 4 gift from dad it worked fine was plying games on it wii sports came with it haves 5 or 6 games on 1 disc all could play up till not long ago kids not played on it for a little while but...
the Nintendo wii is a glorified dvd player with a few major exceptions. it sounds like the units optical pickup has dust or debris on it. try the
Wii Lens Cleaning Kit at amazon for 10 bucks. very common and simple fix.
http://www.amazon.com/Wii-Lens-Cleaning-Kit-Nintendo/dp/B001GZT1UI
Aug 12, 2010 | Video Game Consoles & Games
No sound while playing a dvd jvc8040b receiver
Make sure the the necessary input of the tv is select to be able to play the sound from your DVD. Also check to make sure you are pluging in the sound cords into the input sound of the tv and not the output. Make sure the source of the tv that you selected to play the DVD through has a sound jack associated with it.
Sep 12, 2009 | JVC RX-8040B Receiver
I have video but no sound from the TV
hi there send it back to nintendo the sooner the better here is there phone number for them to collect it and repair
> Nintendo UK
Quadrant
55-57 High Street
Windsor
SL4 1LP
Tel: +44 (0)870 6060247 (Calls charged at National Rate)
Fax: +44 (0)2392 383 444
Registered at
Companies House, Cardiff, (31st January 2001)
Company No. FC022968
Branch No. BR005889
Managing Director
Satoru Shibata
if you need any othere phone number or address ill be happy to post it up for you cheers
Thanks From Me and FixYa
Feb 02, 2009 | Nintendo Wii Console
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
Panasonic CT-32SL14 flat screen tv stopped working
We played Wii sports and fit for few hours than tv started to flicker and change colors to green and black and white. We shut down Wii and not TV screen doesn't show any picture. The power is there and the sound... but the screen is just blue. Any one experienced anything similar?
May 20, 2008 | Panasonic CT-32SL14 32" TV
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Connecting receiver/dvd and vcr combo and TV
do u have rca outs form the tv to the aux in of any dvd system sterio unit
Jan 10, 2008 | Sony DAV-FC8 System
Mitsubishi WS-48311 48" Rear Projection Television Logo
218 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
