Western Digital 500GB My Book World Edition 500 GB Hard Drive
Problem for Western Digital 500GB My Book World Edition 500 GB Hard...
When I connect to My Book it doesnt not read the
By nhat_truong7 on Oct 11, 2009
When I connect to My Book it doesnt read the drive... My Book just flashes on and off the lights. The WD icon on my PC flashes also and reads (RAIDO -Bad)
Best Solution
posted on Oct 11, 2009
Very Helpful)
pabloloco
Rank: Guru
Rating: 93%, 239 votes
If you are running Vista, You might be one of many people who are reporting an update that is causing some buggy behavior. Try this:
Connect the drive but do not Format the drive, right click 'my computer' then 'manage' go to 'storage/disk management' view the drives; your usb drive will not be allocated a drive letter. You can set one manually or leave it for about 2~5 minutes for one to be allocated auto. Each time you connect the drive you may have to do this.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 14, 2009
Not Rated)
JonT69
Rank: Guide
Rating: 0%, 0 votes
OK, For All so-called Experts, Read Up on The Drive Model Details First.
The MyBook World Edition is a NAS accessed via network only.
The USB connection is for an additional drive only.
Therefore all these 'Answers' refering to Windows USB issues are superfluous.
If the Blue-Ring Flashes it is usually an indication of the Internal HDD overheating - or at least the sensor reacting - perhaps prematurely.
Especially if it works ok for a while then flashes.
1 - Try vacuuming the drive around all the vents to remove as much dust etc as possible - even if in psuedo dust free enviroment - we all shed skin, otherwise there would be very little dust around.
(Just putting on my isolation suit to go to the spare room darling...)
2 - Relocate the unit if horizontal, then vertical and vs. versa. AND to a different location even move to a clear(er) area and blast with a fan - see if it lasts longer.
3 - If in warranty back up your data (with item 2 above)(how ever tedious) AND get it replaced. Yes, buy a backup for the backup if need be !!
4 - If out of warranty OR you want to try (all disclaimers apply) OR you don't care - but are interested follow the wiki hack mybook site and hack into it via SSH and treat it as a new non-wd drive and disable 'S15wdc-heat-monitor' in the '/etc/init.d' - just to seeif makes the blindest bit of difference - if it does then it's a good workaround to keep the drive alive to backup all data whilst considering replacing the drive (identical make & model preferred) or at least acknowledging the sensor within may be at fault. If your that concerned you'd get detail on how to open the unit up and manually monitor the hdd temp to rule out the internal drive sensor fault.
Food for thought.
JonT
Was this helpful?
Yes
No
Popular Solutions for Western Digital 500GB My Book
Questions and Unsolved Problems for Western Digital 500GB My Book
Do you recommend Western Digital 500GB My Book World Edition 500 GB Hard Drive?
Answer
Answer
very slow to open files, several do not open. does not allow deletion of files, all files affected... (More)
Answer
I have a WD 500GB My Book World Edition and only need to use it for back up...problem: I've hooked... (More)
Answer
win7/ WB5000ME drivers? I cannot access the disk or format it but Vista seems to have no problems?
Answer
For the most part, South America became a collection of independent states between:
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Western Digital 500GB My Book...:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14928
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
