Question about Fujitsu Plasmavision PDS-4233 42 in. Television
Fujitsu 42" Plasma PDS4214W-S
I recently acquired this television from an office building. They could not get the picture to show up so I told them I'd take it.
I got it home and tried several input sources including my computer and my playstation2 (I didn't try the S-Video as I don't have a cable, only coax and there's not coax input).
When I power it up the red light changes to green as usual, and the screen flashes on for one second then goes black. I can get no sound or picture. I cannot see menu options on the plasma when I push the menu button.
bluegreenash
  • 661 Answers
SOURCE: hitachi cle-990
not sure your model number is correct please check here is a manual for the 42 CL plasma TV http://www.hitachiserviceeu.com/scripts/userguide.php/CL42PD2100_EN.pdf if it is a different set please check the model number, this should have a 42 in it (as it is 42")
Posted on Sep 27, 2007
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
gilheero
  • 207 Answers
SOURCE: High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Posted on Feb 05, 2008
  • 124 Answers
SOURCE: Fujitsu Plasmavision 55"
Hi, The problem comes from the power supply board. The power supply board is a three phase unit. One phase on the power supply failed, that would be the reason for the no picture. You can have the power supply board repair or replace. If you are within the manufacturer warranty, they "should" replace the part ( power supply board) at no cost to you. Mike
Posted on Nov 02, 2008
  • 534 Answers
SOURCE: Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Posted on Jun 05, 2009
Troubleshooting a Fujitsu plasma screen. No picture, or audio.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 29, 2015 | Fujitsu Plasmavision 42" TV
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Jul 11, 2010 | Fujitsu P42HHA30ES (Bundle) 42 in....
42" plasma tv problem
Hello, If you are referring to the actual shape of the prongs coming out of the tv plug(refer to figure): prs1-6980390t98.jpgif the prongs look like this, you will have to acquire an ac adaptor for your TV, this adaptor you can locate at any radioshack store, and sometimes it's called foreign ac adapters for US use.
or simply look at the radioshack webpage, it should be listed under ac adapters.
Apr 13, 2010 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Fujitsu P50XHA10E no picture
See Fujitsu Service Bulletin on this problem. -see link below
Oct 24, 2008 | Fujitsu P50XHA10 50 in. Plasma Television
Fujitsu pds4209u-b 42 plasma
Chances are the PDS4209 has a broken axis board. I don't think the 4203 has the same board. I don't think the 4203 compnents can run the 4209
Apr 03, 2008 | Televison & Video
Fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Feb 12, 2008 | Fujitsu Plasmavision 42" TV
Fujitsu Plasma 42' approx 4 yrs old
HI , i have the same problem . it is either the power supply unit or the plasma display panel . I am problem solving it currently . generally the cost is about $1000 (aus) to fix . it is worth doing as fujitsu are outstanding plasmas .
if u need service manual pls email me at all_ps2_sales@hotmail.com and will send service manual .it has the the checks to do so u know which part needs replacing . U need some experience to do the checks
hope this helps
Dec 12, 2007 | Fujitsu Plasmavision PDS-4221 42 in....
Fujitsu Plasmavision PDS-4233 42 in. Television Logo
251 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
