Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Walmart song problem - wma.
I just got a c250 for Christmas and when I try and sync the wmas I've purchased from Walmart, it tells me:
It is not possible to obtain device's certificate. Please contact the device manufacturer for a firmware update or for other steps to resolve this problem.
I have the firmware updater on the computer. What's the solution for this?
I Formatted mine and it now works. Go under settings on the player.
Posted on Dec 26, 2007
I have the same issue. I hope we get an answer to the issue.
Bought a gpx8gb digital media player for my daughter for christmas. I have downloaded her cd's into itunes library. Now how do I get those songs onto her media player?
Check to see that when you rip a music CD that your music is not copy protected. The RIP function in your Windows Media Player will allow you to convert the music CDs you have purchased into either an MP3 or a WMA format.
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Choose the type of music file as well as the quality with which you would like to save the music. (Your GPX player has the ability to play music files in both the MP3 and WMA format.)
  4. Make sure to use MTP when transferring copy protected WMA files.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
  1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In Device Setup - Configure Sync, write a name for your mp3 player.
  3. Click Finish. The window closes and the Sync feature in the Player is displayed.
  4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
  5. Select the songs or entire albums from the center pane.
  6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
  7. Click the Start Sync button on the Sync List pane.
  8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
  1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In the Device Setup Wizard, select Manual.
  3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
  4. Select the Library option. On the left pane select Sync List.
  5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
  6. Select the songs from the center pane, and drag them to the Sync List.
  9. Good Luck, I hope this helps
  10. Please rate me, Thank you
Dec 09, 2009 | GPX MW3836 MP3 Player
Transfer WMA files to Sansa c250
There two types of WMA file - protected and unprotected (also called "DRM-free" and "DRM-encrypted"). Some protected or encrypted WMA's may allow you to play back on your computer, but will not allow you to play those same files on an mp3 player. There are only two ways around your problem - one is expesnive, and one is illegal:
1) You can purchase additional rights on Overdrive to transfer your audiobooks to a "portable device" (by which, they include mp3 players).
2) You can download a program such as Tunebite to strip the Overdrive of it's DRM license, rendering the file of its protection (I would NOT reccomend this route).
The WMA files that you had that worked before were either unprotected, or were protected but had transfer rights.
-Tha Mp3 Doctor
Mar 19, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Problems with downloading
Only use songs that are in mp3 format - some of the songs were DRM-encrypted WMA's with fixed-term licenses.
-Tha Mp3 Doctor
Dec 12, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I got a gpx MW3836 1gb mp3 player. i cant get any music on there from my wondows media player lists. my playlists songs might have been copy rights protected on it. i want toknow how to get my play lists...
Converting wma's to mp3 costs money unless you are getting the songs from an actual CD. Better to get an mp3-only music service like Limewire, Rhapsody Mp3, etc.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Windows media player not working
i know how to fix it.. i tried my phone with same prb .. but it is now solved.. i will tell u the method..just get ur phone reset
Oct 24, 2008 | Samsung Blackjack SGH-I607 Smartphone
Reformatting songs/mp3 player
The Sandisk site says that your dad's device should play .wav, .mp3 and .wma files. Has the player EVER worked? I got a C250 for my wife as a Christmas present and my computer recognized but refused to communicate with it UNTIL I DOWNLOADED AND INSTALLED THE FIRMWARE UPDATE. The player was a paperweight until then. It turned on and played the demo files pre-loaded on it, but I couldn't transfer a single file into it. Just a thought. Here's the link:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
good luck.
groove_guy
Jan 01, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Mp3 format??? HELP, PLEASE!
I don't know about converting the MP3s to WMAs, but I had the same problem with "corrupt files."
What fixed that for me was instead of dragging and dropping files onto the Sansa, I synchronized them using Windows Media player, but only do 10-20 songs at a time, because if you try to do too many, they probably won't show up. I know it's tedious and annoying, but that's what did it for mine :) I hope this helps.
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
Got a new SD Card + Card Reader but when I download my music on it...
You cannot just move WMA songs onto the card and play in the MP3 player. MP3 format may work this way, but for sure the player only seems to be able to recongize WMA files when syncd through Windows Media with the USB cord attached. Be sure the DESELECT 'copy folder hierecy' under the sync options/properties of the MP3 player drive or SD card drive.
When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer folder hierecy. The MP3 player is not able to reconginize the folder structure it usually creates.
This player only seems to be able to transfer MP3 format with Vista, using windows media player sync. I can syne MP3s formats, but not WMAs at all. Unless someone found otherwise
Dec 25, 2007 | iLO (2 GB) MP3 Player
Music downloads
Try download Bearshare or Limewire for free (they also have pro but it costs) and download the songs and sync them to a folder or your mp3 player.
Sep 20, 2007 | Nextar MA933A MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
