Question about Nintendo Wii Console
Color picture for my wii
I have purchased the wii system hook it up to my tv but its i black and white any solutions in getting it in color.. thanks
  • 1 more comment
  • Olivia Corrigan Dec 26, 2007
    My son only received wii off santa yesterday, worked perfectly but when he went to play it this morning, its in black and white, have tried putting all cables in proper sockets, resetting it etc. no luck, would really appreciate some help with this, thanks!!!
  • Anonymous Dec 26, 2007
    we have a new wii. can only get b&w picture, componet colours are green, blue,red ,white,red. colours on lead are yellow red white. what goes where. have tried all options i think. can any body help.
  • fedup2 Dec 26, 2007
    We also have a b & W picture but on the odd occasion we maybe lucky and get colour, but if we connect it to a portable TV hey presto it works every time, what can we do with the main TV?
  • 3 Answers
Hi again,
I left the wii for a couple of hours and put in a different game and it worked again, strange!!!!!!
Posted on Dec 26, 2007
Maybe the component cables are not working, try buying a new component cable.
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Mar 06, 2012 | Nintendo Wii Console
I have hooked my wii up to a new samsung 42"
Make sure that you have switched the Wii to component video in the system setting menus. Once you have done that, you should have a color picture in 480p! Hope this helps!
Feb 27, 2011 | Nintendo Wii Console
I have had my wii for a while and it is black and we hooked it up to our flat screen Vizio and it is only in black and white but then when i hook it up to my older tv it is in color and i cant figure out...
Did you use the Component cables for the new tv? If you did, you need to go into the System Menu of the Wii, and change the output to Component 480p, and that should give you a color picture with a higher resolution. Hope this helps!
Feb 23, 2011 | Nintendo Wii Console
When I try to hook up my nintendo wii to an hdtv I get a black and white picture? The RCA cable only has 3 cables and the input on the tv has 5 outlets.. could this be the reason? how can I get it to work?
The RCA cable you are using is meant for standard resolution TV's. There should be a spot on the HD TV for the standard RCA cable. This will resolve the black and white color issue but unfortunately you will not get the benefits of your HD TV. Your best be is to get a composite cable for the Wii. You can get the cable from target or wall-mart but online shopping will typically result in a cheaper price.
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 26, 2010 | Nintendo Wii Console
TV went to black and white when hooking up the wii
You probably don't have something hooked up right or connected all the way. If you are using component video cables, make sure that all of the different plugs are plugged into the matching socket on your TV. Also, make sure you have your TV on the right channel (3 or 4) if that's how you have it setup.
Otherwise, you will want to look at the input settings on your TV and make sure you are receiving the correct input, and if you have your Wii plugged into a VCR instead of directly to your TV, try hooking it up directly to see if it works.
If that doesn't work, try using a different TV - especially if it's a TV you know works in color with a Wii. If it is still in black and white, you might need to take it back to the store and exchange it for a new one.
Nov 23, 2009 | Nintendo Wii Console
My av cables for the wii dont work
switch the colors around till it works. You are getting a video signal, but the colors are back wards. Are you hooking it up composite, component, or HDMI?
Aug 13, 2009 | Nintendo Wii Console
Plug in the wii system and everything comes in black and white
Try plugging it into another scart socket, this sometimes happens when a tv does not support 60hz. the result is a screen that has no colour. You could try just plugging it onto the seperate av inputs. Most tv's these days have one scart that will work ok and in colour.
Jan 18, 2009 | Nintendo Wii Console
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Black and white screen
is the TV's color settings set to black and white maybe???
Jun 20, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
269 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
