Question about GE Americana 15.6 Cu. Ft. Top-Freezer Refrigerator
GE refrigerator door problem (model TBX25PAYARWW)
The door is hinged on the right and when I close it, the left side droops and I can see the light still on above the door seal. Pulling up on the handle seals the door tighter and the light goes out. How do I fix the problem?
  • 288 Answers
Is sounds like you will have a broken or worn out or bent hinge. It may be a combination of the 3.
Posted on Dec 26, 2007
Item comes with right hinged door...I need left hinged door.
On some models you can move the hinges and door pull to the opposite side. On the side without a hinge, you would see plugged holes (plastic plugs covering the holes). You may have to move the top right hinge to the bottom left and bottom right to the top left (opposite of this for a left-hinged refrigerator/freezer).
You may need help to do this, and be careful.
Jan 27, 2016 | Refrigerators
Gr Side-by-side refrigerator freezer makes noise when door close
It is possible that the hinges of your freezer has moved and shifted the alignment. So first of all use a WD40 cleaner to spray into the hinges and the areas around it. Now move the hinges violently for some time and check if has lessened. If so repeat the spraying. See if here is dirt accumulated along the hinges if the door is not moving parallel just push the end up a little . You must be able to get the hinge to shut properly by this correction. Hope you try . Good day
Jul 31, 2010 | GE Refrigerators
I have a GE side by side. The freezer door will not stay sealed or closed anymore. I have to tape it shut. What can I do?
make sure unit is level side to side and front to back if still problem check door seals first for and ice build up, ripped or debris if good how much product on door is something sticking out if all good--than need to adjust hinges with help loosen top hinge screws and with some holding door shut loosen lower hinge with door level and closed retighten door hinges try door if still problem readjust
Feb 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side doors are not alligned
here is a diagram of the doors and the hinge area. Without seeing myself I can only gusess.
you box could be twiked or not level. The hinge at the bottom could be bent. There top hinge sometimes can have an ajustment that moves the top of the door left and right wich will raise the door a littel. to see if this has an ajustment you will need to remove the top cover of the top hinge and loosen the bolts a little and move the door left and right, if it does have someone hold the door where you want and tighten.
Jan 11, 2010 | GE GSS22SGM Side by Side Refrigerator
Our side by side freezer door opens slightly
That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
Jan 03, 2010 | GE Refrigerators
How do you adjust the doors to closed completely?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Sep 03, 2009 | GE GSH22JFR Side by Side Refrigerator
Same problem but part is not on schematics for my model.
that is what helps your door close..if the cams are broken the door will drop down and may drag..if that is your situation then yes, get that kit.
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Doors need adjustment
You should be able to take the top trim caps off the door hinges, loosen the hinge screws a little, and move the door(s) away from the center of the refrig, then re-tighten the hinge screws to get the doors to stop hitting each other. You may want to check the bottom hinge(s) for the hight. The bottom hinges and the bottom of the doors have matching plastic "ramped" washers, which raise the door as it is opened, which help them to self close. If one of those is broken, the hight will be off.
Mar 14, 2009 | GE GSH25JFR Side by Side Refrigerator
Suddenly our GE side-by-side fridge door doesn't shut
Check the bottom of the freezer door at the hinge to see how it is suppose to look and work, assuming the freezer door still works right. Then look at the ref. door and compare.
Sounds like something is broken or damaged. Usually there is a white tefflon washer which is beveled to allow the weight of the door to help it close. Check with an appliance parts store, you may be able to buy just the washer or the whole hinge assembly may come in a package.
Jan 25, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Refrigerators Logo
217 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
