When I try to print on my lexmark x73 printer, the paper will pull down into the feeder and stop half way. Then the green light onthe left will blink continuously. What should I do to get the paper to continue to feed through the printer.
5 Other Users Have The Same Problem
Comment by Guest, posted on May 21, 2008
My paper isn't catching either. My lexmark X73 won't scan either. I just got it from my uncle a few days ago and it worked great until today. The green light just keeps blinking. Help!
Comment by peady5, posted on May 16, 2008
paper is not catching through feeder
Comment by Mr JW, posted on May 07, 2008
My paper goes about halfway down and then stops. I have tried "force" pulling a sheet through to unjam it, but it isn't jammed. I also tried feeding it a thicker sheet of paper. Next, I will try the solution offered below and disassemble it. If that works, great. Otherwise, I'll just have to buy a new printer. However, we've had this one several years and find it is easy enough for my 87 yo dad to use.
Comment by Lynn1947, posted on May 02, 2008
I have had my printer for many years and it too jams half way???????? How do I fix it and can I get it apart? Linda Michigan
Comment by Guest, posted on Feb 09, 2008
my paper is getting stuck in my X73 Lexmark..I see how to fix it...but how do you get the printer disassembled??
Thank you...
Comment by olasNick, posted on Apr 28, 2008
But to be honest these printers are so flimsily put together it's very easy to break when taking apart and you may be better off getting an all in one that's better made.
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Lexmark X73 All-In-One InkJet Printer
Email this problem
Can you Help with these Printers problems?
lexmark5495 printer
Lexmark x7350 will not scan,...
printer won't print
X73 found loose spring
clicking printer
