Hi, I can't guaranty this will help the problem, but for a quick try I say its worth it. On the Desktop, right click to open Personalize, select Display Settings; by adjusting the resolution it helps with the "Flicker effect" aswell, by selecting different settings, you can "view" the best Monitor Display. "If the solution helped, rating it is appreciated, thanks."
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
See if you can plug in and external monitor and boot from scratch if the external scren comes on then the LCD on the laptop has had it. Ring Toshiba to get it fixed as its in Warrenty.
