Question about HP Pavilion ZV5220US (PF143UA) PC Notebook
External monitor how come when i hook up the tv to my laptop via monitor cable i just get a black screen on my hdtv flatscreen?
  • 69 Answers
Try going to Control Panel on your computer and going under the display option. Under Settings you will find two monitor options. On the display number two, try selecting that to extend your windows by checking the appropriate box.
Posted on Dec 26, 2007
I purchased a component cable (rectangular plug I think called VGA plugs into female left side laptop toward the back and red, blue and green RCA type jacks for LG TV.
Look for a Function Key (fn) on your laptop for activating the VGA external monitor.
If your fn button is blue (for example) all of the keys on your laptop that are activated when you hold down the fn button will have an option in blue. Look for a blue icon on a key that roughly looks like a monitor or two monitors.
With everything hooked up, press and hold the fn key, then tap the corresponding key to turn on the external monitor.
Having said that... the cable you are describing has a VGA (blue 15 pin connector) that plugs onto the VGA jack of your laptop and splits that signal into a set of component RCA plugs. Its critical how you plug these into the correct place on your LG TV component connections. I know such adapter cables exist but I've never seen one work.
Sep 06, 2017 | Acer Computers & Internet
The screen on my acer aspire 3100 crack so i bought a vga cable to connect to my flatscreen but the picture switches back to my laptop when its starts up the only way that it works on my flatscreen is when...
Go into your display settings. It should show at least two different monitors. Your laptop monitor and the external one your plugged into. Click on the external one and click on the two check boxes. Click on extend the desktop into this monitor first. Then click on this is my main monitor. Reboot your computer and it should be on your external monitor.
Jun 12, 2013 | Computers & Internet
How to turn on
What?............Oh, okay.............I was going to watch this Disney movie though..........
JUST KIDDING!
http://www.asus.com/ph/Notebooks_Ultrabooks/ASUS_VivoBook_X202E/
1) Laptop OFF, monitor OFF, attach a VGA monitor to the VGA port, on the laptop.
(Right side, all the way to the back)
Or you can use the HDMI port, and use an HDTV.
The HDMI port is on the Left side.
Turn the monitor/TV on.
Turn the laptop on.
Does a display show on the external monitor/TV?
No?
Hold the Fn key down, and tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
Go to what you are using as an external monitor. VGA monitor, or HDTV. Hold the Fn key down, and tap the F8 key until you get what you want.
Have a display on the external Monitor/TV?
Problem is NOT the graphics chipset.
Problem is the Video Cable, or LCD/Touch screen.
Post back in a Comment, as to the results of the external monitor test.
Regards,
joecoolvette
F8 key is display toggle over
Apr 25, 2013 | ASUS VivoBook X202E-CT033H Touch Laptop, 1...
MY acer ZD1 screen has gone black how do i connect it to a pc screen blind
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Right/Rear of the laptop.
Example of a VGA connector (Port), and a VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for an example of a VGA Cable.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Yes. You can also connect an HDMI cable to it, and HDTV with this capability.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY
Press, and hold down on the Fn key. At the SAME time tap once on the F5 key. The F5 key is the Display Toggle-Over key.
Regards,
joecoolvette
Feb 19, 2013 | Acer Aspire 5920-6423 Notebook
Acer 5515 on external monitor
Get an VGA cable and connect your external monitor to your laptop via a VGA port that is usually used for digital projectors. In this VGA port, you can initiate dual monitors.
Then look at your keyboard and look an icon in your function keys (F1 to F12) that looks like a pair of an LCD and a TV like this {LCD icon/ TV icon}. In most laptop keyboards, this is located in F4.
When found, and with the external monitor hooked to the laptop via VGA port using a VGA cable, press and hold down the FN key and press the function key where the icons described above is located. Example, FN + F4 to toggle a single and a dual monitor.
Give it a try.
Jun 26, 2010 | Computers & Internet
Hooking laptop to tv says invalid format on my
After it is all hooked up. You must go to main computer screen, then right-click on main windows screen,
You will see box #1 and box#2
Take the #2 box, click and hold mouse button and drag to the Left Side of #1 and let go of mouse. Get it as closely matched up to the #1 box without crisscrossing them. Just set it directly next to the box.
Then click enable this monitor and/or apply button.
Then ok,
Now your monitiors should all automatically connect and turn on.
Feb 28, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a dynex TV I am trying to connect to my laptop via HDMI. The TV works fine as far as displaying cable but when I try to hook it up to my laptop the screen displays for one second then flashes to...
Make sure that you set your laptop to external display by using the proper F key, located on top of the keyboard. It looks as though there are two computer monitors on it. My Gateway is F4 for example. Press the function key and the proper F key simultaneously. There are a few choices, so you may have to push it more than once. I hope this helps and good luck!
Please remember to vote 937f12f.jpg Thanks.
Oct 31, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
S Video cable
you need to toggle the display on your laptop. be sure that when you connect the tv or external monitor the laptop should be turned off. to toggle the display kindly press Fn followed by F8. for old tv's you need to have an S-video cable. for LCD monitors, either VGA or DVI cable will help.
i hope this info helps you.
Sep 09, 2008 | Dell Inspiron 6000 Notebook
Flatscreen Monitor
yes you can provided that you have all the cables and connectors for the monitor
Apr 12, 2008 | Computers & Internet
HP Pavilion ZV5220US (PF143UA) PC Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
