Question about RCA P52926 52" Rear Projection Television
PCB for a 52" RCA Rear Projection
I have a RCA 52" rear projection tv #p52720BA. The buttons that allow the channel selection as well as volume do not work.
There is a PCB behind the cover. I am thinking this is the problem. Is this part available anywhere and does this seem like a possible solution. The power on and off button is the only one that works
    President:
  • 4,402 Answers
Solder Bridge on power switch to ground SW13201
Posted on Jan 09, 2008
I have a RCA rear projection tv. The colors need
If you can get to the menu you should be able to select options by using the volume and channel buttons.
Feb 28, 2010 | RCA Televison & Video
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca rear projection screen way to much blue
replace convergence ics .press the menu and go into the convergence
alignment.see if you are able to align the blue convergence. if not replace the convergence ics.
Aug 04, 2009 | RCA P52771AT 52" Rear Projection...
Rca 52" rear projection tv (P52926) volume control LOCKED!!!
This can be a tricky one, I would check the 5 and 3.4 volt lines first with a DVM (analog meter will not due) then with a scope to see what the voltages are and what they look like. A bad cap on the rail for the e-prom can cause this or the eeprom may be bad, this also happens. It might be best to contact a scv. co. as you can a lot more problems in that area if your not familiar with it.
Feb 26, 2009 | RCA P52926 52" Rear Projection Television
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
D52W19 RCA 46 inch t.v.
my RCA D52W19 52" rear projection TV will not power up ( turn on )
Nov 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA 56 projection
Does the buzzing come from the speakers or the back...turn the volume down.. is it still there?
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52926 52" Rear Projection Television Logo
111 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
