Question about Husqvarna Designer I
Screen is frozen
Messages will come up on screen but when you try to touch screen to get a new one to come up nothing happens its like it is frozen or something. what can i do to fix the problem?
  • 2 more comments
  • michelle1513 Jan 05, 2008
    thanks for the advice but nothing happens at all its like frozen all together. I think i pushed to many buttons at once and overloaded it. i hope i dont have to send it in to get fixed cause it will probably cost me an arm and leg!
    yes ive tried all that, i am not sure if it under warranty it was my grandmothers and she passed away a year ago and gave it to me. How would i find out if its still under warranty or not? thanks for advice
    its a 2.0
  • bcac3 Nov 09, 2008
    I have the same problem. I am running version 2.22.
  • 201 Answers
Are you saying that nothing at all happens every time, or sometimes you get the wrong thing i.e. you touch Prog and Rep screen comes up? Have you ever recalibrated your screen? This should be done regularly - at least every six months, but I do mine monthly. The catch is that in order to do this, you need to access the Set Menu and if your screen is not responding at all this would be impossible. In the Set Menu on the last page (I think) there is a "Color Touch Screen Adjust" button. Use this to access the calibration screen, and you must touch exactly in the centre of the two crosshairs until they turn green. Instructions are on Page 31 of my manual.
Posted on Jan 04, 2008
  • 1 more comment
  • Pamsquilt Jan 05, 2008
    Assume you've tried simply re-booting the machine i.e. turning it off then on again - but wait a good minute or so before turning it back on. This is a long-shot, but try turning it off, attach the embroidery arm, then turn it on again. Or, if the embroidery unit is attached, turn machine off, take off arm, then turn on again. Is it sewing at all, or is everything frozen up? Take out any floppy disk or USB stick you have in the machine before re-booting.
    I am sure I read somewhere in the manual about re-setting everything back to factory settings, but cannot locate that information now. I belong to an online group specifically for the Designer 1 machines so I will ask them for advice on this and will get back to you.
    Got to admit it's sounding like it does need to go to the repair shop, but hang in there a bit longer and see what I can find out. Is it still under warranty? Warranty is 5 years but I think the screens have a separate warranty. (Mine was second hand and already out of its warranty when I got it, so not sure of details.)
    Pam
    When you turn it on, do you get anything on the screen or is the screen black? If you do get the start-up Husqvarna motif, look in the lower right corner and make a note of the Version number - it might be 1.64 or 2.0, 2.1 or 2.2 - or maybe something else again! Get back to me with this number. I have an idea to try. But if the screen is black - it needs to go in for repair.
    I don't know how you would tell its age. Did you get all the paperwork with the machine - maybe the receipt is tucked into the manual or something? Where on the machine does it say "Designer 1"? On mine, it is written underneath the screen. Newer ones had it written on the flap at the top of the machine. Does it have "ESS" or "Exclusive Sensor System" written on it? Newer ones had that, mine doesn't. In any event, you would most likely need the receipt in order to get it fixed under warranty. Would you be able to find out where your grandma bought the machine - they would have a record of its date of purchase.
    Maybe you should just take it in for repair - after all, if you did not have to pay for the machine it would still work out a cheap machine for you all up. You could also get a service done at the same time then be confident of having a machine in tip top working order.
    Anyway, get back to me regarding the Version number. I will write again to you with a suggestion when I know what number it is.
    Pam
  • Pamsquilt Jan 06, 2008
    Michele - I would like you to try updating the machine software to see if this will kick-start the screen. You can do this two ways: download the update file from the Husqvarna website, or I can send you a zip file. The version available on the website is 2.2 and some have had a few issues with this version - I did not update to 2.2 because it did not offer me anything I needed, and I did not want to see whether or not my machine would have these issues. However, it might be worth you giving it a go. The "issue" they had was that they had to hit the Start button twice to start an embroidery - no big deal, I agree, but something I could do without. Can you handle the update procedure? There are full instructions on the website on how to download and how to install. You will need a new floppy disk to do it. www.husqvarnaviking.com - go to embroidery/embroidery machines/Designer 1 USB (don't panic if yours isn't USB) and use the red links to get to the download page. If yours is NOT USB make sure you choose the correct download file.
    I have 2.1 installed, and I have saved the zip file on my hard drive. I can email you this if you would like it, but you would need to contact me privately not through this online group. Also, I have the USB and am not 100% sure my file would work for you. We can try it if you like, but I think you would be better off using the Husqvarna one.
    Let me know how you get on. It might not work, but it's all I can think of and might be enough to get the machine "thinking" again. Otherwise - it's off to the repair shop, I'm afraid.
    Pam
Why wont my Bernina 170 QE embroidery unit work
Electronics fail eventually. It is a bummer because I bet you love your old Bernie. Electronics are nothing for the novice to mess with unless they have loads of component level experience. I would take this to your sewing tech and have them check it out. (maybe get a new one?)
Jul 21, 2014 | Bernina Artista 170
My Kenmore 19001 touch screen works when I am sewing regular stuff, but when I put in the embroidery card - I can see the designs on the touch screen but nothing happens when I try to go to a design. I...
to recalibrate the machine press the stop/start; the reverse; and the knot button at the same time and while holding it down turn the machine on.
Sep 28, 2012 | Kenmore 19001
.legge@hotmail.comMy designer 1 Touch Screen
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again. This will calabate machine the screen.
Hope this helps
Mar 22, 2011 | Husqvarna Designer I
HOW TO CALIBRATE MY DESIGNER 1 SCREEN the screen is off if i touch program nothing happens and the arrows are off to the right side
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again,and it should be fixed. Regards, Cathy.
Sep 15, 2010 | Husqvarna Designer I
Original designer I and the touch screen is frozen.
The front cover will have to be removed to access the componets to find the problem... it could be as simple as a loose connection or as complicated as having to replace the touch screen. Removing the front cover is not a simple task if you do not have experience in working on this machine. I would suggest it go in to an "authorized dealer.
May 15, 2010 | Husqvarna Designer I
Touch pad on front frozen up
The machine is a "computer" and needs to be repaired by the dealer.
Mar 14, 2010 | Husqvarna Designer I
Janome 300e touch screen not working
The screen has something stuck around the edges or its damaged, have you tried to touch all parts of the screen to see anything happens? If you need more help 612-270 2957
Jun 22, 2009 | Husqvarna Designer I
When I turn on my designer 1 the needle is off center to the right, not centered. Also when selecting a zig zag or other decorative stich it sews something different. Have tried recalabrating the screen no...
These machines are computers are just that: COMPUTERS. Nothing to do but have a mechanic ltake a ook at it for possible fix. It is not communicating with the brain since settings are off. There is a manual on ebay for $5.99 that is a three-part CD and I suggest you go on-line and buy it. It will hep with parts, service and how-tos for your D-1. I have it and find it invaluable for fixing my own machines. Hope this helps.
May 14, 2009 | Husqvarna Designer I
The touch screen is scrambled and frozen
Mar 07, 2009 | Husqvarna Designer I
Touch screen not responsive
You need to re-align the touch screen using the following routine:
Accessing Alignment Mode:
Then you will see a text message something like
"Press + to align"
STOP
Don't touch the "+" in the text message !!!!!
The one you want will be elsewhere on the screen and all on it's own, with no text around it.
Using the non pointed end of a needle, or the spare spool pin (nothing sharp) gently but as accurately as you can, touch the centre of the +
The + will move to several more locations as it organises the height, width and orientation you give by touching the centre of the + as it appears each time.
When it is finished, turn machine off, then on as normal.
If this does not correct the issue, it may well be something else, so please, if you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Jan 06, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
452 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
