Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Kitchenaid Superba 42 Refrigerator Leak under Freezer when Water Used from Door
Kept finding small puddles under fridge; checked drain pan and it was fine. Finally spotted the culprit today when pouring numerous glasses of water from the door. Somehow the water leaks underneath when water used from the door. Any ideas on what's happening?
  • 473 Answers
Either the water filter isn't seated properly or there is a crack in the tubing or the water line isn't seated properly in the coupling behind the grill at the freezer door. Also, inspect for breakage in the line in this area as well (coupling area).
Posted on Dec 26, 2007
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
How do I fix water leak from the Kenmore Coldspot side-by-side refrigerator
I would say or ask how is ur defrost timer working as this seems to indicate that ur build up of ice is more than normal hence u have more water build up that should usually be evaporating from the compressor heat and ur drain pan should not be so full. some other things to consider are below:
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
u can test the defrost timer as well
May 06, 2015 | Kenmore Refrigerators
I have a top freezer Maytag refrigerator. Water condenses on the "ceiling" of the refrigerator section enough to drop onto the top shelf and form small puddles. Otherwise, the refrigerator seems to keep...
first make sure the door of your fridg is closed very good, check in your freezer behind the back wall that the drain is clean and water can flow down.
Dec 29, 2009 | Refrigerators
How do you replace the water filter on a Kitchenaid Superba refrigerator. I can find the filter.
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
My refridgerator leaks water every two weeks
check to make sure the drain pan is in the right place. If it puddles up inside the bottom of the fridge first, your drain hole is plugged up. for this, you wil have to remove the access panel in the back of the freezer side to get to the drain hole. you may also have a crack in your drain pan.
Aug 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Small puddle of water on floor in front of fridge
there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
May 23, 2009 | Bosch Logixx KDR40423 Refrigerator
Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Oct 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
I have a Rca Refrigerator...Freezer on top and fridge on lower half...I noticed a puddle of water a couple of months ago on the floor under the fridge on the linoleum floor..I mopped it up and this...
HI. thanks for your question. the problem is with a clogged drain tube, located under the freezer. and goes down to the drain pan. to repair. turn fridge off for at least 24 hrs. use a small plastic hose . go to the drain hose, by the drain pan. push small hose inside the drain tube, up as high as you can. now blow in the tube to clear. thanks the appliance doc. please rate my answer thanks.
Oct 08, 2008 | Refrigerators
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
Oct 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
843 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
