Question about Fujitsu 24R1 Air Conditioner
Air Conditioner - Fujitsu - 24R1 - Electrical Installation
I have had a second hand wall mounted split system aircon installed. Once the installation was completed by the electrician he noted that it would blow the incoming mains supply fuse (& not the aircon breaker). The compressor was running and "loading up" just before the fuse pops. The inside unit would not " turn on" by the remote or by the manual operation button. The electrician said it was because of a fault with the compressor and promptly left. On speaking with a another electrician who feels the mains supply was hooked up incorrectly to the aircon. Since we are in the Holiday period Fujitsu are not open and I was hoping someone may be able to help with a electrical hook up diagram so I could give it to the second electrcian. We are currently experierencing 40`c so any help would be good.
  • Phl71 Dec 26, 2007
    Internal unit model# AST24RSG-R
    External unit model# AOT24RWGL
    I have been to the Fujitsu General website (Who are separate from Fujistu) who only have a operational manual. I have looked for a installation guide but could not find one. I have searched on the web and found a installation guide for a different model but could not trace it back to Fujitsu for other guides.
  • Phl71 Jan 05, 2008
    Problem fixed, after some investigation with other Fujitsu aircons the electrician and forgotten to check the wiring diagram on the internal unit and hence my problem. I got him back 4 days later and after telling him what needed to be done which was remove the power cable from the compressor and attach via isolator switch to the correct power feed cable which was tucked behind some pipework.
  • 104 Answers
Posted on Jan 24, 2008
What is the hourly labor rate 2 install this unit
Trades will be very reluctant to give you an hourly rate on split system install as this would deplete the profitability. It depends on the installation, a simple back to back install would take around 3 hours with electrical connection to switchboard. It also depends on brick or fibro walls. Most installations are around 500 Aus dollars total price with the longest time frame of around 4 hours
Jun 10, 2014 | Fujitsu "AOU30CLX1 30,700 BTU Halcyon...
Regassing of fujitsu splitsystem airconditioner
All split ac can be regassed, but if it was only installed recently and the gas has leaked out then it will either be a manfactures warranty job, or if it was poorly installed it should fall under the warranty of the installer. most cheaper installers however only give a 3-6 month warranty on thier work if they give one at all. If it is uses either R410 or R22 gas (it will say on the outdoor unit) than any liscensed and i stress liscenced installer can fix the leak and regass it.
Feb 13, 2008 | Fujitsu 36CS Air Conditioner
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Fujitsu 24R1 Air Conditioner Logo
1,055 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
