Question about Apple iPod nano
No Music My iPod won't play my music.
  • jon13210 Dec 26, 2007
    I'm a reporter just seeing what happens when i post a question. Obviously, ignore this...
    President:
  • 317 Answers
Welcome to Fixya, it's a great site where people can find answers to virtually any technical question.
Posted on Dec 26, 2007
My ipod won't play music
are you sure the music format is right ?
Jun 27, 2012 | Apple iPod Photo MP3 Player
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
My jensen vm9214 will play my music from my ipod but it will not show a display of the song or anything and when I click pause or play or fast forward on the screen it doea not do it so I have to play and...
First off, is the unit equiped as ipod ready or are you using an auxillary input. If your unit is ipod ready, this means it has the ipod cable to the unit. If you are using an auxillary input, it won't show the name and yes you will have to control your music from the ipod itself. Just some things to think about. If your unit is malfunctioning, I recommend visiting the local stereo shop.
Aug 14, 2011 | Jensen Car Audio & Video
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
Jul 07, 2011 | Sony ICF-C1IP (Black) Docking Station
I will try and make this as short as possible and hope you understand what I am asking. I just got an Ipod Classic last month and signed up with Itunes and then downloaded about 1300 songs from my cd...
You can't "backwards sync" (put music from your iPod back onto your computer) through iTunes. When you went to sync after you got your fixed computer back, I'm assuming iTunes tried to copy what was in iTunes (nothing) to your iPod, which probably is what caused these problems.
Assuming you still have the music on your iPod, I would recommend transferring the music from your iPod back to your computer (to a folder other than iTunes), restoring your iPod to factory settings, then moving all of the music files into iTunes and re-syncing your iPod.
There are two programs that are available to transfer songs from your iPod back onto your computer. The first is iDump and the second is YamiPod. I have found that iDump is the better of the two.
The link for iDump is:
iDump
Hope this helps!
May 14, 2011 | Apple iPod classic MP3 Player
I have the ICF-CS10iP dream machine my ipod (which is a 2nd generation touch) will charge but wont play music what is wrong it use to beable to
This happened to me - the radio also wasn't playing. I was able to resolve it by resetting the unit using the instructions in this manual: https://docs.sony.com/release/ICFCS10IP.pdf
I hope that helps!
Jan 25, 2011 | Sony ICF-C1IP (Black) Docking Station
Computer says songs are there iPod says there not
your ipod will not function properly with windows media player. it may play the music but it won;t get functionality from the ipod.
You have to use iTunes to get your ipod straightened out. Once you mount it on iTunes you will see the music and be able to add music and delete music.
May 24, 2009 | Apple iPod classic 7th Generation
NO FILES
your ipod won;t play videos.
but to put files on it, mount it to itunes and when the iPod mounts you will see the picture of the nano.
in that window click on manage music manually.
now click on the music folder and it will open.
in windows explorer open the file folder containing your music files.
click on a song and drag n drop it into the left most column of the music listing window in itunes.
it will load into you ipod.
One thing you will have to remember, Ipods will not load incompatable music or other files.
make sure your music is compatable.
May 12, 2009 | Apple iPod nano
Ipod nano 8g
Did you place the music on your iPod via iTunes, or just drag and drop to the device?
The music must be added through iTunes, or the iPod will just act as an external hard drive--storing your music, but you can't play it.
If you just dragged and dropped, take it off your iPod, start up iTunes, then add the music that way.
Nov 15, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod nano Logo
24 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
