Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
HP F1903 FLAT PANEL POWER PROBLEMS
I HAVE AN HP F1903 LCD FLAT PANEL MONITOR ,WHEN I PRESS THE POWER BUTTON ON THE MONITOR THE ON SCREEN MENU SHOWS FOR A FEW SECOND THEN THE MONITOR SHUTS OFF, TRIED ON TWO COMPUTERS WITH SAME RESULT DOES'NT STAY ON LONG ENOUGH.
ANY HELP WOULD BE THANKFUL .
  • G3nEsjs Oct 15, 2008
    F1903 flat panel monitor only displays video for a second or so, (power light orange), then enters standby mode (power light blue). Problem happens on both VGA and Digital connections and any resolution.
  • 74 Answers
Internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Posted on Dec 26, 2007
HP Pavilion F1903 flat screen monitor dimmer with grey lines
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Hp f1903 flat pc monitor goes black after 5
I was given a faulty f1703 by someone as it was out of warranty, had no help from HP and bought another brand replacement.
Same problem everyone else seems to be having. Press the on button, came on for a second or so and then went blank. Press button again, turn on again and the same happened.
I managed through trying time and again after pressing on to quickly press menu, then go down to Factory settings, press select, go down to Yes and press select again. This reset to the Factory settings and it seems to be working okay. Been like this now for about a week. I don't know how long it will last - if it goes again will try re-soldering. Guess I won't be buying HP products as this was a part of a very expensive system.
Apr 29, 2010 | HP W2007 LCD Monitor
What causes a dark screen and a flashing power button for a HP Pavilion F1903 19" flat screen monitor?
Probably find the screen inverter has failed and needs replacing. Can be a fiddly job as you have to dismantle the monitor so take it to your repair shop if you're not familiar with this type of repair.
Apr 28, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
May 17, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My monitor is stuck in a constant color loop...
What you are seeing is a test they use at the factory. Here are the instructions to reset the monitor:
1. Press the MENU button
2. Use the + and - buttons to choose Advanced Menu
3. Press the SELECT button
4. Select Factory Reset
5. Select Yes
6. Press MENU again to remove the onscreen menu
Hope that helps :)
Dec 13, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Hp flat panel problem
There is a common problem with the power board that needs about $6 USD in parts from radioshack. Search Instructables at the MAKE site...
Nov 11, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
224 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
