Question about RCA Lyra RD1072 MP3 Player
The first time charging my mp3
My flash MP3 player says that it has to charge for three hours at least before using it. Well i plugged it in and I can not tell if it is charging or not. How do I tell, and if it isn't, how do i get it to charge?
  • oxymore Feb 17, 2008
    I have a ZEN stone plus MP3 player. I can't seem to charge it up despite leaving it plugged in for four hours to the USB port on my computer.
I have the same model as pictured. It don't have a rechargeable battery. You just need to install a single AAA battery in the back.
Posted on Jan 02, 2008
  • 4 Answers
THAT MODEL USE BATERY ¿WHERE ARE YOU PLUGGED ?
WRITEME
Posted on Dec 31, 2007
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Michelle
Authorized Finis Dealer
Get Swimp3 Deals at WaterproofMusic.com
May 21, 2010 | Finis Swi MP3 Player
HOw long do you have to charge the mp3 player on the computer? I just got it. Does it say charged on the player when it is finished> I see the battery on there flashing and it says connected
With any new battery device, the first charge should be at least 12 hours, and when the battery is flat then it needs to be charged up for 12 hours again. This needs to be several time for the battery to reach its full charge capacity.
When the battery is fully charged the battery indicator be firm and not flashing.
Jan 21, 2010 | SanDisk Sansa Clip MP3 Player
How Long Do I Charge Before I Can Put Songs On?
You can do it while plugged in to usb charger. Otherwise you can do it 2 hours after. It should be charged for about 6 hours
Oct 29, 2009 | Philips GOGEAR SA6045 MP3 Player
Unable to switch on
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Sep 29, 2009 | Creative Labs ZEN Vision:M Digital Media...
Charging
By plugging it into your computer - takes about 3 hours the first time. Make sure your hold/lock switch is not engaged, or the player will not charge.
-Tha Mp3 Doctor
Jan 08, 2009 | SanDisk Sansa Clip MP3 Player
Wont charge
hi , first a hall you have to plug in to your usb in the pc ( attention not on distribution usb 4 plug or 6 plug will not work let me know yvon chow !!!
Dec 30, 2008 | Philips SA3025/37 Flash MP3 Player
Cannot tell when sansa mp3 player is fully charged.
Make sure the hold switch is not engaged - it will interfere with the charging process. Here is a link to the full user's manual:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Won't Charge
On some systems, the usb does not supply enough power for battery charging, so it briefly comes on, then goes off. Also there are power adapters with a USB plug on them for charging things that use the USB for power. You may have to end up buying one. Though they are very usefull now that more and more devices use the USB for battery charging power.
May 24, 2008 | Insignia Pilot MP3 Player
Charge
Charging the Player
The player needs to be charged before it can be used and every time
the battery gets low. It takes approximately 2.5 hours to charge the
Player. Once fully charged, the Player lasts approximately 8 hours.
To charge the Player:
Remove the USB cover on the Player.
Connect the Player to the PC using the Flash Plug.
The Player will begin charging. The battery indicator should begin
to flash, alternating red and green.
Once the battery is fully charged, the indicator light will stay red.
Note: If this is the first time the Player is connected, wait until
Windows detects the Player and follow the prompts to install it.
Mar 15, 2008 | Disney Tink Digital Mix Stick MP3 Player...
Unable to charge battery on Audiophase MP3, model KZ111
Try using the AC charger for the mp3 player, If It does the same thing, Ur MP3 is defective and u can return it with out the receitp sayin that it was a christmas gift since most eleftronics have a 1 year warranty
Feb 07, 2008 | Audio Players & Recorders
RCA Lyra RD1072 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
