Question about Microsoft Xbox 360 Console
How do i make the cd work even thought it is scratched
I need help my xbox 360 i was playing a game on it and i moved it and the game has a scratch in the middle and it does not work wat do i do
  • dfgfdfgd Jan 04, 2008
    my disc is scratched
Go to like gamestop or sumthing and get it de scrached is it a really bad scrach if not then do what i said if so then you cant do anything
Posted on Jan 09, 2008
Game will not work
Check back side of disk or any scratches or dirt, wipe of game with soft damp cloth. Please know if there are too many scratches or if the scratches are too deep, then replacement is be required. If there are no scratches or dirt, try other Xbox 360 games to for sure verify that it is the game that is the problem and not the Xbox 360. If the game is at fault and the Xbox 360 can play other games, and there are no scratches or dirt, then it’s a faulty disk, and needs to be replaced. Hope this helps!
Jun 02, 2010 | Bethesda Softworks Fallout 3 for Xbox 360
Put in disk in 360. Play Playonline viewer, but screen goes black, and says cannot read disk, need to clean or restart. I did this several times and same result.
I had this problem recently. What happened was you closed the game without logging out of Playonline. The long shut down I call it. This corrupts the FFXI data on your HDD. And since FFXI does not appear in the memory you have to format your HDD and redownload. I can guarantee if you put the disc in your xbox with no HDD that it will read or even place it in an xbox with a HDD that has never had FFXI.
Dec 26, 2009 | Square Enix Final Fantasy XI for Xbox 360
My xbox 360 won't play my Fifa 09 game. I accidentally moved my xbox while the game was running and i heard the disc rattle. Didn't notice anything weird cause i stopped playing at that time. I go to play...
When you accidently moved your Xbox while the game was running, it probably put a scratch on your FIFA 09 disc.
You can try to fix it by using a cd /dvd scratch repair kit. You can find them at just about any store that sells cd or dvds.
I had a disc that wouldn't play and used one of the repair kits on it because I had nothing to lose. As I was applying the solution to the disc, I thought.... this is a complete waste of time.
When I wiped the solution off and put the disc in my Xbox, I had no expectations that the game would work. Well... I was wrong, the disc actually worked.
There's no guarantee the repair kit will work in your particular case but, you're in the same boat I was in... You've got nothing to lose by trying.
The only other option is to buy a new disc.
Sep 13, 2009 | Microsoft Xbox 360 Console
Big rings on the disc
A common problem that XBOX owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “ring of death marks”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is usually required to repair any scratches or laser burn on discs. They can be fixed!!!
For further help on XBOX & XBOX 360 disc repairs, visit:
www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
Check the “More Info” & “FAQ” Sections for further details on game disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
You should contact Microsoft for assessment and guidelines.
Hope this Helps!!!
Mar 27, 2009 | Microsoft Xbox 360 Elite Console
My xbox 360 keeps puting scratches on my games
check to see if anything is obscuring the disc tray on opening and closing.
If there isnt check the disc make sure its smooth and flat no bumps and not bent
if there is noises like grinding when playing it may be a part inside causing this
i suggest calling xbox because i dought u want to risk doing this to other games.
please rate. thank you
Dec 17, 2008 | Microsoft Xbox 360 Console
Disc scratching from xbox 360
Laser burn, looks like complete or partial circular scratches around your disc, also known as “ring of death marks”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is usually required to repair any scratches or laser burn on discs. XBOX laser burn discs can be fixed!!!
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair. Check your garauntee and contact Microsoft for assessment and guidelines.
Hope this Helps!!!
Dec 05, 2008 | Microsoft Xbox 360 Console
Xbox scratching the Rockband CD
this means some one either bumped the 360 or moved it vertically while playing ....this makes the outer ring on games there is now way of fixing the game
Apr 27, 2008 | Microsoft Xbox 360 Console
Disk Scratched By Xbox 360
Lazer burn!!!happens to a load of my discs too usually doesnt kill em though
Mar 26, 2008 | Microsoft Xbox 360 Console
My xbox 360 game keep getting scratched when i play
http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm
Jan 14, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
