my screen colors change by itself, sometimes is last in matter of seconds and somtimes it take up a few minutes, and or is just a quick flickering. look like a light blues cover the whole screen. I tried to mess around with color setting and the connectors but still can't solve the problem and the monitor is fairly new and here is the model (Dell 1908WFP) Flat Panel Monitor.
it isnot softwere fault. probley we get this problem in old moneter. few in new. causes of loose part of bord and back side fitting part of moniter glass. it can be fix by electronix tech. it is called colour fade.(nepal)
monitor takes several minutes to wake up after being in sleep mode. Use to wake up after moving the...
(More)
monitor takes several minutes to wake up after being in sleep mode. Use to wake up after moving the mouse or tapping the keys in a few seconds now it takes several minutes to wake up.
On startup when it's cold it comes on for a half second, then turns off. I must cycle it on and off...
(More)
On startup when it's cold it comes on for a half second, then turns off. I must cycle it on and off for a half dozen times before it comes on and stays on... I suspect I need a new on/off switch (button). What say you? Where around Seattle can one get repair service?
