Whirlpool LTE6234D Top Load Stacked Washer / Dryer
Problem for Whirlpool LTE6234D Top Load Stacked Washer / Dryer
Washing machine filled with water and then stopped
By jdrozda on Oct 11, 2009
Washing machine filled with water and then stopped mid-cycle. This happened before and the repairman said it is a door switch. He removed the lid and in 5 mins moved something at the back of the machine. Where is this switch located?
Best Solution
posted on Oct 11, 2009
Very Helpful)
lilhelper
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 53 votes
the lid switch for you model is located inside the cabinet of your washer. you should be able to access it by removing the front panel. by inserting a putty knife or similar tool on the left and right side along the seam of the cabinet. you should be able to feel two small clips that hold it in place. lift up SLIGHTLY on these clips and remove one side at a time. once you have done this you may need to release the top as well, held in by two 3/8 hex screws. the lid switch is on the right. and is held in by two phillips screws and a wiring connection as well remove the two screws and the connection and replace it with a 3355458 lid switch. hope this was a help to you
Thanks
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Whirlpool LTE6234D Top Load
Questions and Unsolved Problems for Whirlpool LTE6234D Top Load
Do you recommend Whirlpool LTE6234D Top Load Stacked Washer / Dryer?
Answer
Answer
why wont the water stop draining from the washer even though the drain is situated above the tub's... (More)
Answer
machine violently out-of-balance in spin cycle in last working load. Evened out load; no avail.... (More)
Answer
It wont spin, the motor is going - but the machine will not spin to get the water out the clothes.
Answer
how to replace dryer belt on whirlpool thin twin stacked washer dryer with pictures?
Answer
I have a new Whirpool 24" Washer With Electric Dryer - LTE5243WH. I pluged it in, Dryer Works.... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , MD
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
