Home | Sony | SDM-HS73P (Black, Silver) 17" LCD Monitor | I turn on the desktop
Sony SDM-HS73P  17" LCD Monitor
Problem for Sony SDM-HS73P (Black, Silver) 17" LCD Monitor
By jiheeahn on Oct 11, 2009
i turn on the desktop and the monitor only says no input signal input2: HD15 go to power save what do i do?
Solution #1
posted on Oct 11, 2009
Not Rated)
denz_maveric
Rank: Wiz
Rating: 85%, 112 votes
Hi jiheeahn! I wiull be glad to assist you. lets isolate the issue. The reason why the monitor says no signal input2: hd15 got to power save. the connection from the monitor to the desktop computer is disconnected or its not connected to the right input connection on the back of the desktop computer. please check the connection from the monitor to the desktop computer, all connection should be hand tight. Then restart the computer, once the computer restarted on the booting process you should hear a beep sound. and display will pop up on the monitor, if still there is no display from the monitor, try to connect a different working monitor to the desktop computer. If the problem still exist, there is a possible problem with your video card, turn off you computer, unplug the power of the computer to the wall outlet and open the your computer in order for you to see the mother board, look for the video card, remove it from the motherboard and try to clean the gold plated part, the contact were you snap it to the motherboard, rub the gold plated part with an eraser (steadler) in order to remove the dirt that is stick on the contact, then insert the videocard back to the board make sure that its sitted on the slot. then connect the input cable from the monitor to the videocard input and turn on the computer, this should fix the issue, if the problem still exist, replace your video card..
Popular Solutions for Sony SDM-HS73P 17" LCD
Questions and Unsolved Problems for Sony SDM-HS73P 17" LCD
Do you recommend Sony SDM-HS73P (Black, Silver) 17" LCD Monitor?
Answer
Answer
thin green like 3.5 inches long on the right side from the bottom
Answer
will not show display power button does not work(stays on) when connected to 110 display says -no... (More)
Answer
I have a Sony SDM-HS73 Monitor and the screen gets distorted and them will go crazy with lines and... (More)
Answer
plugged it into my laptop and did the same thing, so it is the monitor which is only 5 yrs old. Is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony SDM-HS73P 17" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
