Question about GE 32GT740 32" TV
Dark picture we connected a video game to the tv,,aftrwsrd when we tried to watch tv the picture is real dark
  • 979 Answers
Disconnect the game and revert back to your old hookup. Better now?...accordianman
Posted on Feb 19, 2008
No picture
im sorry to ask but is this with your video game system or just with the tv its self just to clear things up a bit
Oct 28, 2016 | Video Game Consoles & Games
JVC TV THE PICTURE IS DARK EVERYTHING ELSE WORKS GREAT
there so many things which can cause that to happen an these are thwe following,
i a tube has to be tested
ii a line transformer
iii vedio amplifier
this tests can be done in w/shop where other tvs are of the same.
Mar 27, 2009 | Televison & Video
My TV makes a loud buzzing noise whenever there is a bright picture on
This is usually caused by video signals overdriving circuits. Too much video causes what you are describing. This is sometimes caused by a bad cable or connection, either a TV cable or a video cable. Hopefully it's not a projector problem. If you can check the connections from your receivers and VCR with the projector on you might be able to pin point the problem. Be gentle and if there is adoubt about a cable, just replace it.
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Sep 17, 2008 | Samsung HL-R6168W 61" HDTV
I have a Toshiba 32af44 TV, the picture is dark on most channels and when watching dvd or playing video games. What do you suspect is wrong? TV was manufactured in 2005.
Hello CAPTKING,
Your TV specs as a flat screen and not a projection TV. So this diagnosis is for that of a flat screen CRT. It appears that your filament voltage might be low or the CRT cathodes have excessive oxidation on them. These are the two primary reasons for this type of failure. The secondary reasons would be low video signal, problems with the screen, focus, or control grids, or low anode voltage (which would also cause picture shrinkage). I would suggest that you take the TV to a qualified TV repair shop to have the work done.
Have them run a diagnostic on the CRT with a CRT analyzer and check the CRT voltages with the TV connected to a video analyzer set at the normal configuration for a color picture.
I hope this helps
Thank you,
Shuttle83
May 26, 2008 | Televison & Video
Blotchy picture
I get this too with my Samsung. Are you watching HD content or standard (cable, satellite) tv? If it's the latter, that's why. The lack of quality really shows on analog signals. The shows that I Tivo look horrible a lot of times. Another thing is the connection to the television. If you are using standard RCA connectors, try switching to either component or HDMI.
Hope this helps.
Feb 01, 2008 | Samsung DLP HL-P5663W 56" TV
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
Black Screen
Ok, this is probably what has happened, you say that you have played games on your tv, well the thing is with HD and Plasma Screen tv's is that when you play Hi-Res games on them the games backdrop will burn itself into the screen, causing the screen to turn dark and not reveal the correct picture it should. People need to learn about this!!!!! Playing games on HD and Plasma tv's will screw up your resolution!!!
Jan 19, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
GE 32GT740 32" TV Logo
47 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
