Maytag MSD2732GR Side by Side Refrigerator
Problem for Maytag MSD2732GR Side by Side Refrigerator
Water collecting on bottom of freezer coming out
By cindy_ron on Oct 11, 2009
water collecting on bottom of freezer coming out of vent
Clarification Request
Posted by lilhelper on Oct 11, 2009
Your problem could be caused by a number of things, you could have a clogged drain pan or tube. this can get clogged with ice and when your defrost heater comes on to melt this ice, it isn't allowing it to drain so it goes into the bottom of you fridge and of course out. the ice build up could be caused by a bad defrost termination switch, or possibly a faulty defrost heater. i would remove the panels at the back of the freezer section to expose the fan and drainage, this will tell you if there is ice building up or not.
Best Solution
posted on Oct 11, 2009
Very Helpful)
woodchuck789
Rank: Guru  Maytag Refrigerators  Expert
Rating: 91%, 644 votes
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Maytag MSD2732GR Side by Side
Questions and Unsolved Problems for Maytag MSD2732GR Side by Side
Do you recommend Maytag MSD2732GR Side by Side Refrigerator?
Answer
Answer
fridge is leaking water underneath onto floor is there a tray under fridge that needs to be emptied
Answer
water hookup was disconnected for months. after connection water dispenser and ice maker not... (More)
Answer
water and ice side does not dispense. water pipe was broken and fixed now the dispensers are not... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , IL
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
