HP Photosmart 8250 InkJet Printer
Problem for HP Photosmart 8250 InkJet Printer
The computer stops loading and waits for
By wayneb754 on Oct 11, 2009
The computer stops loading and waits for approximately 2 minutes before continuing to boot. When we removed the hp Printer usb Plug and the computer boots fine. Please help. Thank you, Althea Mason
Best Solution
posted on Oct 11, 2009
Very Helpful)
Msoft IT Pro
Rank: Guru
Rating: 87%, 89 votes
The symptom you described happens because your printer is capable of reading memory cards.
When you turn on your pc with the USB cable connected, your pc is checking the memory card slots in your printer to see if any of them contain a valid operating system that can be used to boot the pc.
Once your pc determines the memory slots do not contain a bootable operating system, it then continues the boot process and loads the operating system from your hard drive.
When you disconnect the USB cable, the memory card slot are not present and the pc boots normally. I've run into this exact same situation at work with certain models of HP printers.
My best recommendation is to check the BIOS in your pc to see if it is possible to disable the option that allows your pc to boot from USB devices.
When you first turn on your pc, the screen will display a message informing you of which key to press to enter the setup program. This is where you want to check to see if the USB boot option can be turned off.
Note: Not all pc manufacturers provide an option to disable booting from USB devices.
If you can't disable the USB boot option, check to boot order to make sure the internal hard drive is listed before any USB devices.
I have to say though, setting the boot order so the internal hard drive appears before any USB devices does not always solve the problem even though it should.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for HP Photosmart 8250 InkJet
Questions and Unsolved Problems for HP Photosmart 8250 InkJet
Do you recommend HP Photosmart 8250 InkJet Printer?
Answer
Answer
printer will not pick up paper from lower tray.
Answer
ink system failure and can no longer print. refer toprinter documentation. error 0xc18a0101 turn... (More)
Answer
removing date battery on hp officejet 145
Answer
when using full size paper, get a message that the paper is the wrong size and will not pick up.... (More)
Answer
my photosmart 8250 printer do not print blackm text
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , DE
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
