Question about Cornea MP800 18.1 in. Flat Panel LCD Monitor
Cornea flatscreen mp704 monitor
I hit the power button and turned the monitor off while I was trying to leave the computer up. When I attempted to turn the monitor back on it did not respond. It happened once and somehow I got lucky for it to come back on. I unplugged it and pressed buttons and one of the times I plugged it back in it came on. Someone else in our home turned it off again and I have not been able to get it to come back on.
  • 74 Answers
I have a similar problem i believe the power button on the monitor is faulty,sometimes it works sometimes it doesnt.what works for me is to hold the button until the monitor comes on and release the button quickly.
good luck.
Posted on Dec 26, 2007
Where can i find a power cord for a Cornea CT1700? I live in Greensboro, North Carolina
josdcabr, do you need only the cord or the "black-brick" switch-mode-power-supply" 12vdc @ 3.5 amps rating. You might try unitedsale. com in Valley Stream N. Y. 12fixlouie
Aug 10, 2010 | Cornea CT 1700 17" Flat Panel LCD Monitor
Need driver for Cornea MP704
Hi
I have the same monitor on one of my test benches. For a long time I tried to find drivers for this because I thought it would make a difference. Finally a year or so ago I found a drivers company which said they had it. For $20 I could download it and many others. I did so and didn't really see much improvement when I installed it. I finally got to thinking that maybe I should look closer at this code I purchased. Well as I suspected this code was actually the Microsoft generic LCD monitor code which had been relabeled. I turned it over to Microsoft. But to answer your question I have never found drivers that are specific for any Cornea monitor. Sorry
Mar 24, 2010 | Cornea MP 704 17" Flat Panel LCD Monitor
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
Cornea CT1700 monitor has no power.
i think that is not monitor problem, that is your computer (cpu) problem.plase chack your ram memory,open your cpu door and remove your ram and clean it with cloth and restore back.your problem will be solve thank you.
Dec 22, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
Flatscreen monitor
Solution: The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
Connections not connected properly Make sure that you are connecting the monitor to the back of the computer in the 15 pin (illustrated below) or older computer 9 pin connection.
video.gif If the computer is properly plugged in, make sure it's getting getting power.
If you are not receiving power from a known working wall outlet and if the power cord is removable, replace it with the one connected to the computer and attempt to power on the monitor again. If the monitor still does not get power or it is not removable, it is recommended that the monitor be replaced or serviced at a local TV / Computer repair shop.
If the monitor is receiving power, check the status light.
If the light is orange or flashing ensure that the monitor is not in a suspend mode by moving the mouse or pressing a key on the keyboard. If the computer does not get a display by moving the mouse or touching the keyboard, turn off the computer and monitor and reconnect the data cable from the back of the computer, and if removable, the back of the monitor. Turn the computer back on; if you still encounter the same issue, continue reading through the other possibilities.
Monitor settings are not correct Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibility.
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting .
Hope this works for ya/ Please dont for get to Vote.Thank You
Jul 18, 2008 | Dell Dimension 4600 PC Desktop
My Cornea CT1702T flatscreen monitor does not turn on; and, I noticed there is no light on the power adapter. Is there a fuse in the power adapter? Do I need to buy a new power adapter; or, can it be...
it's a repairable. and there is no power adapter in monotor u just chek out monitor with bcabinet power cable if yr monitor light show on then just change yr power code it's cost just Rs. 40 to 50.... first do this way otherwise take yr monitor to repair or call yr system wander to chek powwer cable.
thanks for using fixya.
jo_chinmay
Apr 03, 2008 | Computers & Internet
External Monitor
No. This is almost certainly a setting issue. Go in to the control panels and change the way the monitor is used. I.E. extension desktop, mirror, etc. Then check the settings for the second monitor and make sure it is not set to some huge size or resolution. This is a function of the MacBook and OSX. I had a similar issue when connecting it to a 71" DLP.
Apr 01, 2008 | Cornea MP 704 17" Flat Panel LCD Monitor
Power Supply for Cornea CT1700 LCD Monitor?
cornea lcd monitor, Monitors Projectors, Computers Networking items on ... Power Supply Adapter Cornea CT1700 LCD Monitor (12V 5A) $18.99: 12vAdapters Dot Com ... Items that are listed in a currency other than U.S.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Cornea Monitor Troubleshooting CT1700
it could be something as simple as your power settings in control panel> power options, then the first window called power schemes pops up and all monitor, harddisk and system standby should be set at never. Also check on you monitor menu for any power saving options and turn them off. If the monitors still turn off then there has to be a deeper fault with the monitors and not with the power options.
Apr 28, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Cornea MP800 18.1 in. Flat Panel LCD Monitor Logo
153 people viewed this question
Top Cornea Computers & Internet Experts
giarcnameloc
Level 1 Expert
Tom Chichester
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
