Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Philips projection screen 55pp9363
I have a Philips 55PP9363. No picture screen is dark.Threes CRT dosen't light up. No filament in the Blue CRT, but Red and Green CRT have filament. No screen volts.Flyback isn't oscillation.
The action I take is, change the Flyback change the damper,change convergence IC's, Issue remain the same.
Any help will be great-full.
HDR LSM ASM is the problem. Philips part number 313503711011. Contact parts store on line at www.partstore.com for part.
Posted on Mar 24, 2008
51'' Philips rear projection TV with color issues
Philips has had a big problem with there coolant fluid becoming cloudy. The only way to clear it up is to have the fluid changed. With every projection crt tv there is a layer of cooling fluid between the face of the crt and the lens. This coolant cools the face of the crt. Over time the coolant breaks down and the light coming through gets distorted. The crt's have to be removed from the set to do this.
Oct 13, 2009 | Televison & Video
Green crt arcs ,no picture, sound ok
you either need a new bulb or your bulb is not installed correctly
Oct 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Dark screen
the sound is locked off the TV good picture
Feb 20, 2009 | JVC AV-27320 27" TV
Need to fix the color and screen
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 50PP9202 No Sound/Picture
what where your symptoms before replacing those ic's
Jul 30, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips cloudy screen
Crt coolant needs changing in the Blue and Gree CRTs red usually isnt affected.
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
NO PICTURE AFTER FEW MINUTES/DARK PICTURE/ERRATIC/NO MENU VISSIBLE
Most projections have a removable speaker cover on the front under the screen. Then there is an access panel that you remove the CRT sockets are the circuit boards attached to the CRTs
Dec 23, 2007 | Televison & Video
Dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Sep 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Picture quality
possible blue crt is defective. also the tube needs filament,blue drive and screen voltages/high voltage to lite up. these should be ck'd only by experienced tech or OUCH! john
Aug 20, 2007 | Akai PT4298HD Rear Projection Television
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
