Question about RCA D52W19 52" Rear Projection Television
52" rca model #p52930bl
How do you get the front plastic screen off without breaking it? Need to get it off to clean the inside of it.
thanks
  • sanjeewa05 Apr 03, 2009
    hi
    i have a samsung sp42w5hfx projection tv, internal tv mirror is broken, how to buy this mirror, please help me ...
    sanju
    Sergeant:
  • 308 Answers
The plastic screen itself never gets dirty on the inside, unless a spider has taken up residence nearby. What you are likely experiencing is dust built up on the CRT lens and mirror - which would cause the picture to look dull with low contrast and brightness. If that is the case, you may find on your model that the screen either pulls out or that there is a wood piece at the bottom that is hiding some screws or maybe the speaker grill needs to be removed to expose said screws. Be gentle cleaning the mirror, as it is surface coated and could be scratched easily.
Posted on Dec 31, 2007
MY RCA HDTV MODEL D52W20B HAS NO SOUND. WHAT DO I NEED TO DO TO FIX THE PROBLEM
Replaceing the Audio output may solve the issue, worse case is the small signal board will need replacement
Aug 04, 2011 | RCA P52930BL 52" Rear Projection...
How do i remove protective screen from RCA rear projection tv
hello my name is rico i work on tvs sometimes. you need to remove trhe screws around the back of screen and the front of the tv, need to remove front panel screws around. please feel free call me if you needd more help with this problem. my phone number is 602-810-7149
Dec 29, 2010 | RCA P52930BL 52" Rear Projection...
Rca tv is blurry
2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
May 06, 2010 | RCA P52926 52" Rear Projection Television
How do u fix the security on a 52" RCA HDTV Monitor
You will need to reset your v-chip, refer to your manual for exact instructions if you do not know the code, or call RCA to get it reset.
Jul 15, 2009 | RCA P52930BL 52" Rear Projection...
Front screen
Hi, much easier to access the front screens (there are 2 sandwiched together) by removing the top back cover, be prepared for lots of screws and when you get down to the last 2-3 screws get some help, on the inside of the back cover is a large mirror, some are made of mylar, do NOT clean or even touch a mylar mirror, the others are made of real glass and the back will be much heavier than you think (and very expensive if you break it)once the back is removed you should have access to the bug, good luck, video-tek
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
RCA P52930BL Setting Green Convergence
check conector j19105 to be seated properly.
if this dosent fix it
look in the uper right hand side of light box in the back of the set
you will see the convergence Power supply, remove and replace it.
save your self time and just replace the board.
regards,
daniel.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Big Screen making a loud beeping noise!
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Jul 22, 2008 | RCA P52930BL 52" Rear Projection...
RCA 52" Rear Projection P52930BL
You can adj. from the front panel of the set using the channel and vol. buttons,if the set you have has a ptk 195 chassis,check and make sure you have adj. projection tv in screens of the menu,in not the convergence power supply has failed,replace the reg on the board,part number is 215530
Oct 04, 2007 | RCA P52930BL 52" Rear Projection...
When plugged in, makes beeping sound; won't come on.
The flyback and horz output has failed,if its a ptk195 chassis,most likely the part numbers are 239111 and 237470
Feb 24, 2007 | RCA P52930BL 52" Rear Projection...
P52930bl RCA Projection 52" Remote problem
First thing you want to do with this set would be to unplug it for at least a 24 hour period. if that does not work, the remote sebsor could be defective. if you want to just replace the sensor and not trouble shoot the set, it should be located behind a plasit cover in the front of the set, or located inside the reflection area of the TV set. Differant models are located at differant positions. If you have no electronic experience, play it safe and call in a trained tech to assist you in this repair. Good Luck Please do not forget to rate this thread.
Dec 14, 2006 | RCA P52930BL 52" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
114 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
