Question about GE 30 in. JGP336 Gas Cooktop
My GE gas cooktop not working. Model#JGP336BEV1B8
2 out of 4 units are not working. The sparks are not igniting and they are not making any clicking sounds. Other 2 units are working. I have to turn on the other working unit to help light the other two units on. Can anyone tell me what I need to do to fix this?
  • Anonymous Mar 23, 2008
    I have a JGP336 gas cooktop that slowly one by one the igniters on the cooktop are not clicking. I still have one that still works. Is there any way to fix the problem? Where do I get the parts to fix the Problem?
  • jhfixit Nov 02, 2008
    front 2 burners do not light on my JGP336 gas cooktop.  Ignitor is not clicking.  Back 2 are working.  I've found the ignitor which looks to be a single unit for all 4 burners.  Is this correct and how do I get in to replace it?  If I have to remove the cooktop, I also have to remove the oven to get to the cooktop.
IF YOU PUSH DOWN AND HOLD DOWN WHILE TURNING THE IGNITERS SHOULD WORK.........AT LEAST ON MINE
Posted on Apr 15, 2008
  • 98 Answers
Are the other 2 burners lighting with the spark? If so the other 2 are either shorting before the burners or the sparkers are faulty.
To service, the cooktop needs to be completely removed from the bench and disconnected from the gas as the access is from the bottom.
I could step you through it while watching, but to do it this way is not a good idea. It's probably worth ringing a serviceman.
Posted on Dec 31, 2007
I have a 30 in jgp336 gas cooktop that fails to ignite when it clicks what is wrong, it worked a few days ago and suddenly stopped working
usually the spark module is not put back together properly.
1 make sure the spark unit is clean
2 make sure the gas jet is pointing towards the sparker
3 make sure there is no aluminum foil or other metal near the sparker pulling the spark away from the gas
Jul 06, 2014 | GE 30 in. JGP336 Gas Cooktop
Cooktop model JPG933BEC2BB right front igniter quit working
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 12, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
Profile JGP636 Gas Cooktop: my ignition for the gas cooktop is not clicking...
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 17, 2010 | GE Profile JGP636 Gas Cooktop
I have a cooktop with two JXDR50 units from GE. One failed.
heatman101
May 02, 2010 | GE 30 in. JGP328 Gas Cooktop
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Jan 18, 2010 | GE Profile JGP636 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
GE 30 in. JGP336 Gas Cooktop Logo
258 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
