Question about Sharp CD-DD4500 System
Sharp CD-DD4500 Won't turn on.
I have a Sharp CD-DD4500 that I've had for quite some time and it has been a great stereo. Never abused and rarely used. It all of the sudden has the timer light flashing and if i push the power button it just makes a clicking sound and doesn't turn on, but the light keeps flashing. i tried unplugging it for a while( a week to be exact) because someone told me if i leave it unplugged it will reset itself. But that did nothing.....Please help!!
  • musicfreak Jan 12, 2008
    The same happens to me. It just turns on for 10 seconds and then turns off. The timer light is flashing.
  • 1074 Answers
SOURCE: view timer is stuck on
take your set to a tech your problem is more a technical problem that sounds as you are having a chip problem that controls the timer
Posted on Feb 25, 2007
  • 208 Answers
SOURCE: Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Posted on Feb 05, 2008
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
  • 55 Answers
SOURCE: view timer keeps wont turn on
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons need to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!)
Posted on Apr 14, 2010
SOURCE: sharp 46 aquos model LC46E77UN tv turned off power
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Posted on Jun 04, 2010
How do i turn my timer off on my sharp dd4500 stereo without tbe remote can someone help me please
You can do it by its main menu option. Go to timer setting tag, and set it to Zero.
May 25, 2013 | Televison & Video
Fuel gage quit, turn signals canceler quit, fuel pump quit, won't start
With the bike turned off, remove the TSM/TSSM. This is the security module. Make the sure these connections aren't wet. And quit powerwashing your bike!
May 19, 2012 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
I have a cd xp120 sharp mini stereo andt it won`t read the disc,i bought and replaced the lens but it still says no disc.
To fix this properly the whole laser assembly needs to be purchased, because it comes pre-aligned which is critical when it comes to a set up.
Apr 06, 2012 | Sharp CD-XP120 CD Shelf System
Have a 1996 Toyota Camery. Installed a KDG140 JVC stereo/CD player but the stereo won't work. CD player works great.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Jul 28, 2011 | Car Audio & Video
I want to use my ipod through the headphone jack. is this possible and what settings need to be on to do so
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for
standard stereo to any audio device with a standard RCA input (except one labeled "PHONO").
Get a cable like the one described here:
and connect it into any available analog input EXCEPT one labeled "Phono".
Jul 09, 2011 | Sharp CD-DD4500 System
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
My model is one pictured on your "Ask a Question".
quick-start guide:
operation manual:
Apr 28, 2011 | Sharp CD-DD4500 System
My dog chewed up the wire that go's into the socket and now we rewired it and the cd player doesnt work anymore how do i resove that problem?
sony makes the cheapest cool lookin **** expect this in the future my friend replace tis a shame i know
Oct 31, 2009 | Sharp CD-DD4500 System
Protect error on model # CD BA200 Sharp Stereo
If you are a technician desolder the Audio amplifier IC,and check if the stereo turn on but with no sound.If the stereo turn on the audio amplifier IC is in short circuit and need to be replaced.
Good luck
Jun 05, 2009 | Sharp CD-BA200 CD Shelf System
Sharp CD-DD4500 System Logo
62 people viewed this question
Top Sharp Audio Players & Recorders Experts
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
