Question about Teac Contemporary CD Radio Alarm Clock (SR-L35)
TEAC CRX57 CD Radio alarm clock - Unable to set time
This Machine does not come with a "hour" or "minute" button?
No pressing of combinations of buttons has worked to set the set the time!
plucky@gotalk.net.au
clocksbyted
SOURCE: TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
Posted on Jul 11, 2008
SOURCE: Teac SRL100
Be sure the radio is set to off or standby.
Hold down the alarm button (#1 or #2) until the disply begins flashing.
Use the TUNER/CLOCKSET dial to change the display to the time you want the alarm to go off.
Press the alarm button briefly to return to normal operation.
Posted on Sep 08, 2008
SOURCE: Teac SR-L100 Clock Radio
There is button inside the CD chamber. Press it for a few seconds.
Posted on Sep 30, 2008
SOURCE: TEAC SD-L80
ON THE SIDE OF THE RADIO
Leave the slider in the"OFF" position. Press and HOLD the "Clock Adjust" button.
The light on the front of the radio should be blinking while you hold the button down.
While holding the button down......
To adjust hours: Press the ">>" button on the front of the radio
To adjust the minutes: Press the "<<" button on the front of the radio.
That is all there is too it.
Posted on Oct 26, 2008
  • 10 Answers
SOURCE: Teac R2 clock radio--Cannot set the clock.
Press and hold the CLOCK ADJUST button for more than 3 seconds.
"SET" and "CLK" appear alternately in the display.
Turn the MULTI JOG knob to adjust time.
Press the CLOCK ADJUST button again to finish.
Posted on Jan 03, 2009
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
How do i change the minutes
Assuming that the time display isn't currently blinking (in the set mode), first press the Time button (to the upper right of the Snooze button). Then press the Reverse button (that lets you skip CD tracks backwards). When you have the correct minutes displayed, press Time again. (Note: if you press and hold Time, you will toggle between 12-hour and 24-hour time. The Forward skip button will set the Hour. If you find the wrong part of the time changing, try using the other button and make sure that you are not in the Alarm Set mode.)
Emerson has the manual for their clock radios on their support site: http://www.emersonradio.com/owner_manuals.php . The direct link to the manual for the CKD9901 clock radio/CD player is http://www.emersonradio.com/resources/owner_manuals/manual_1312821795.pdf .
I hope this helps.
(every so often I get a clock that is set in the opposite combination from the manual directions. Usually it's a one-off and the others in that model are set as directed.)
Jan 02, 2012 | Emerson CKD9901 Clock Radio
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
How to set clock on the teac sr-l100 just bought at yard sale, no info book. thanks d
To set the alarm on the TEAC SLR 100:
Hold down the BUTTON for the alarm you wish to set (#1 or #2) until the TIME ON THE DISPLAY begins flashing. Use the TUNER/CLOCKSET DIAL to change the display to the time you wish the alarm to go off. pRESS THE ALARM BUTTON BRIEFLY TO RETURN TO NORMAL OPERATION.
May 28, 2011 | Teac SRL50 Clock Radio
Just purchased, didn't have any instructions in box. How do I set time and alarm? Thanks
Clock: With the radio off, press the Clock Set button, then the Memory button. The time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Alarm: With the radio off, press the Alarm Set button, then the Memory button. The alarm time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Sep 19, 2010 | Memorex MI4019BLK Alarm Clock Clock Radio...
Matsui Radio Alarm CDCR200 set the clock time, lost instructions
Hold CLOCK SET button down, press HOURS and MINUTES until you get the right time, release CLOCK SET button. This radio alarm unhelpful calls the ON/OFF button "STANDBY"! To turn it on, press the STANDBY button so the standby light is on!
Feb 21, 2010 | Audio Players & Recorders
Unable to set the alarm
To Set the alarm time: Press and hold the ALARM button down, and then press the hour/minute buttons to obtain desired time (Note the PM indicator on the screen for PM times)
To Enable the alarm: Move the sliding switch to AUTO or ALARM (Auto is for radio wake and Alarm is for beeping noise) *remember to turn up the volume knob if using AUTO (radio) setting.
Dec 04, 2008 | Lenoxx Electronics Clock Radio With CD...
May 26, 2008 | Teac SRL50 Clock Radio
Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
Sep 20, 2007 | RCA Radio Alarm Clock
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
109 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
