Question about Sakar DIGITAL CONCEPTS VC-16 Motorized VHS-C Adapter D-VHS Tape
My camera doesnt work at all. it take WAY too long to take JUST ONE picture. and also, after about 2 or 3 pictures, the screen goes all white, and when i take a picture, it just comes out WHITE!!! it annoys me so much. and another thing, it keeps sucking the power out of the batteries i put in, in under half an hour. all of this really stinks because i just got it. if you could help, that would be greatly appreciated.
    Problem Solver:
  • 15 Answers
Re: My camera doesnt work at all. it take WAY too long to...
1st Thing for your batterie issue i recommend Energizer E2 Lithium They are the best value per picture. know for lasting 7x longer in digital camera.
And for the issue regarding the screen going white it sounds to me like a Manufacturer Problem. There is not much you can do about that but return it to the vendor.
It might also be because the bateries you are using are not efficent enough.
My Recomendation: Try the Energizer E2 Lithium and give it another shot. If you still experience any issues you will have to return to vendor.
Hope the Information was Profitable
Posted on Dec 30, 2007
0 characters
3 Points
I have a tosiba computer, recently we had family pictures made we were given the cd to view the photos. when i put it in the computer nothing happens and in my computer settings it doesnt give me the...
Put the disc into your disc drive and then go into my computer. Click on the drive and see if it will read the disc. You might need to install Windows Picture and Fax Viewer to see them. Try the Microsoft website for it.
Nov 27, 2010 | Maxell CD-R 80 Minute 700MB Media...
Have a digital decor 8'' picture frame
I have the same problem, there is a way to get it back on, but it is neither easy nor consistent. I had a power outage at home and it died and was hissing static noise. I have gotten it to come on by cycling the power both by plugging it in and out, and also cycling the power switch as well as fiddling with the contrast thumbwell. Sometimes it comes on right away, other times I have fiddled with the power cord, power switch and contrast for 30 minutes. I does seem to work though not a consistent pattern. I have lost power here several times and I seem to always be able to get it back on.
Aug 05, 2009 | Alpha Digital Blank Media
Camcorder works in PLAY mode, good picture & sound. In REC mode screen is blank
...try to cleaning the camcorder with cleaning tape in the rec mode...
Mar 23, 2009 | Sony (41989) Hi-8 Tape
VHS-C tape jumpy when playing back
My apologies, I overlooked the "-C" in your post.
This problem is due to a type ofcopy protection built into vcr's.
"Macrovision" copy-protection is merely a weakening of a particular part of the signal that makes up the picture and was primarily intended to prevent people from copying videotapes. I imagine almost everyone's seen it but probably didn't know what they were seeing: the resulting picture is a little jittery and is in black-and-white or alternates between black-and-white and color. The reason you're seeing a blue screen is because modern televisions, in the absence of a signal or a weak signal, will just show a blue screen instead of snow or a very poor picture. As mentioned above, you can get around Macrovision by inserting into your connections a signal amplifier that specifically amplifies the portion of the signal that Macrovision diminishes.
Feb 07, 2009 | Maxell HGX-Gold (4 pack) VHS-C Tape
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
Nov 16, 2008 | Blank Media
When I try to hook up my evision123 Digital Camera to my computor to download pictures it says camera is not connected to the computor. What do I do? when i hook up my cam it say no cam is found on my...
it sounds like you need to reinstall the drivers. This is a link to a driver download for th eVision 123 digital camera that has worked for me running Win XP. Hope it helps. Once you download and unzip the file, restart your computer and go to the setup file to start. for some reason the setup file doesn't seem to want to run until you restart. after the software is installed it works great. see the description on the page for more details of what is included in this setup. hope it works good for you too. And remeber to pay good deeds forward, if you come across someone else who needs this driver offer them the same link. DON'T FORGET TO BACK IT UP TO CD!!!! LOL
Aug 19, 2008 | Sakar DIGITAL CONCEPTS VC-16 Motorized...
Deleting pics from memory stick
Option Go to list of pictures and check any menus like(mark ,mark all.delete all ) if have option mark menu -just mark all pictures and select delete. opton
2 if you have mark all -just -mark all -and delete
3.if you have delete all -just -delete all -it will delete all of your pictures in memory card
IF YOU REALLY delete all pictures and all datas
4.if you wish to do Formate the memory stick
now your Memory stick has Empty.
May 15, 2008 | Sony Part 996804671 Service Manual for...
No Picture..
the tapes weren't erased but your video head has to be cleaned. it might be dirty now for not using for while. try to get a head cleaner and that should to it.
May 03, 2008 | Fuji Hi8 Pro Videocasstte 120 Minutes Hi-8...
Sakar DIGITAL CONCEPTS VC-16 Motorized VHS-C Adapter D-VHS Tape Logo
59 people viewed this question
Top Sakar Blank Media Experts
sonny shoeria
sonny shoeria
Level 1 Expert
Are you a Sakar Blank Media Expert? Answer questions, earn points and help others
