Question about HP Compaq Presario V2000 Notebook
Hearing noise while switching on/off
Hi
I have a Compaq Presario V6000 laptop. From past few days I am hearing a noise when i switch on the laptop , it isjust for few seconds . 2days back when i hibernated the m/c and kept at a corner in the room, just after 5 min i heard a loud noise, when i checked the laptop , all the lights were are on, but the screen was blank. i was trying to poweroff , but it didn't go . Then i removed the battery and then kept it again. Later there was no noise. Please help me in finding the problem, was it beacuse of over heat ??
    Novelist:
  • 188 Answers
Hello how did the last solution get a rating?? He gave advice for a desktop not a laptop????
It sounds like something shorted out inside the machine and now its not booting up when you turn it on.
Probably a bad motherboard...hopefully it is still under compaq warranty since a motherboard replacement can run $300-$600.
Posted on Dec 26, 2007
  • 383 Answers
Monitor clicks, pops, or makes other noises. Noise when turned on or off. It is normal for standard computer CRT .
How can I make my computer quieter? If your power supply has a power switch on it, you can easily determine how much noise your power supply generates by disconnecting it from the motherboard.
Good Luck, Read and follow instructions/Please dont for get to Vote/Thank You.
My laptop compaq presario v6000 does not switch on but the power light comes on when the chager is on. when i try to turn the computer on it just flick the light on then back off. can anyone yep me to
The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50.
http://www.chargerbuy.com/original-compaq-presario-v6000-ac-adapter-65w.html
Dec 16, 2012 | Computers & Internet
I have a Compaq Presario V6000. I bought a
It sounds like you have a bad MIC. The MIC is located behind the bezel at the top.
Jan 26, 2010 | HP Compaq Presario V6000T 15.4" Notebook...
Compaq presario v6000 laptop when switched on blue lcd lights on only,can hear fan on but windows does'nt install and nothing on lcd screen what so ever. Every few minutes i hear a click noise and lcd...
It is the motherboard. The V6000, V2000 as well as the siblings in the HP line DV2000, DV6000, and DV9000 all have the same issue. In my opinion is from the oxidation of the motherboard contacts before the nVidia BallGridArray chips are hot air soldered to the board.
As the laptop heats and cools, these .014mm balls expand and contract. Where there is a poor solder pad, the solderball unsticks from the contact surface.
I have repaired 22+ in the month of October alone.
Oct 30, 2009 | HP Compaq Presario V6000T Notebook
Not starting up
sounds like a dead processor
Jun 14, 2009 | Compaq Presario Notebook
Blank screen
Hey Boots_Calara,
In most of hp/compaq dv6000 series that i have worked on have bad ram , easiest way is taking out the ram and replace it. Or if you have a friend that has a hp or compaq laptop switch the ram and try boot it with there ram. Try it before you replace the bad ram.
Jan 22, 2009 | HP Compaq Presario V6000T Notebook
Try fn key, And LCD/TV Or LCD/VGA usually marked on 1 of The number ( Numerical ) Or F Keys.
Remember to switch back before closing down, Otherwise the laptop will try to look for the projector.
The other option is to see, which device is set to boot first from the systems Bios.
Mike @ compurepair.
Sep 22, 2008 | Compaq Presario 700 470024-192 Notebook
Need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
Jul 31, 2008 | HP Compaq Presario V6000T Notebook
usually all drivers for Compaq and HP computer systems (portable and non-portable) can be found on the HP support website (Click here to go to it), simply go there, chose your region, than your country, enter your model number (not the series, the model number, you would usually find it on the service tag, or wherever you would find a serial number), but be sure to chose "Download drivers and software (and firmware)", and than chose your operating system. Hope this has helped.
Jul 06, 2008 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Cannot hear sound
Actually problem with compaq presario v6000 is that when you only install conexant high definition audio driver you get a error ,so first install microsoft universal audio driver and than conexant high definition audio drivers, i hope you have conexant high definition audio if not let me know..
Here is the link for microsoft universal audio
ftp://ftp.compaq.com/pub/softpaq/sp32501-33000/sp32646.exe
_____________________________________________________
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so it will be highly appreciated if provide your feedback..
Thanks for using fixya support..You have a wonderful day
Jun 06, 2008 | Compaq Presario Notebook
Compaq presario v6000 s/n: cnf6412pn1
Compaq Presario V6000 AUDIO SOUND DRIVERS HOW TO GET
Mar 15, 2008 | HP Compaq Presario V6000T Notebook
HP Compaq Presario V2000 Notebook Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
