Question about Acer 90.00012.30B Computer Speakers
Only one of my speakers work
I recently bought a new acer computer (Acer M1620) the speakers are plugged into the jack on the back of the computer. Ever since i hooked up the speakers only the right speaker one will work. :( someone plz help a newb out
  • dognayr15 Dec 26, 2007
    its plugged ino the correct spot but when i do the sound test it does both speaker sound tests on the right side.
  • Anonymous Oct 08, 2008
    well only one of my speakers work and also when i use headphones only one side of the headphones work and whene i tried the heaphones at a friends house they work and ive tried but i jus cant get both sides of my speaker to work.
    PLZ HELP !!! :(
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Dognayr15
Happy Holidays
well, if you put the green cable on the green connector on your sound card, you,ll be fine, and see if work, fine, depending on your configuration speakers, 5.1 or 2 way, you can test if the sound go on the 2 speakers.you also check if something is bad with the other speakers
Posted on Dec 26, 2007
  • Carlos L. Burgos
    Carlos L. Burgos Dec 26, 2007
    Hi again!
    Well, may be you need a new split connector for your speakers jack, then use it instead, of the regular jack, is like a spantion jack, some speakers conectors don't get right to split signals, so you have to buy a expantion jack conector. or ...see if in software have the right speakers balance, and install the ultimate Direct X 9.c version. heres is the page of the jack I talk about.
    http://cgi.ebay.es/PC-Speaker-Extension-...
Need new motherboard, n15235
The Intel DG41RQ Works in the acer aspire m1620-b1209a case
Apr 12, 2013 | Acer Aspire AM1620-B1209A MiniTower...
Acer Aspire 5520 Power Problems! :(
1. Actually the problem is not with the charger / adapter!
2. The plug-in port / jack of the laptop has become loose.
3. Don't try to work out the charging by adjusting the adapter plug with different angles. It will just damage the plug-in port (the wire inside the port will become loose and unaligned)!
4. Contact the Acer authorised service center for repair / replacement of that plug-in port / jack in the laptop! It'll just cost some bucks!
please rate this advice if it helps....tc! :)
Jan 14, 2010 | Acer Aspire 5520-5156 Laptop
Acer Aspire 5720 sound not working
that means the guy or someone who replace the new harddrive didn't to a good job on restiall a new window vista for you, just simply go acer.com and search your model, redownload the sound card driver.
that's it.................
must be sound card driver problem.
Dec 29, 2009 | Acer Aspire 5720 Notebook
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Jul 25, 2009 | Acer H233H bmid Monitor
Make sure the cable is all the way in and that your using the right jack. The green jack is usually the correct one. Make sure any other speaker wires are hooked up properly.
Oct 08, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Acer speakers
hello, check the volume. also the jacks are color coded. green is speakers,pink is mic,blue is line in. if this does not help, consider adding sound card(this will give a better quality of sound than onboard sound) hope this helps! good luck, glen.
Aug 01, 2008 | Acer (90.18612.36B) Computer Speakers
ACER X191 Monitor - Speaker input?
go monitor back side and Saw of spk input point .input point name is line in .then insert the jack and connect ur pc lin out put point for Sound
Dec 13, 2007 | Acer X191WSD Monitor
Speakers
Speaker issue desktop's only
1. Plug USB into USB port (any)
2. Plug Black speak cable into LIGH GREEN (NOT BLACK) connector
3. You will see a popup window - make sure it is on Front Speaker out
4. Click OK - you will a cartoon computer with speakers on either side -then click on one of the
speakers to test
5. if that does not work then follow this:
Reinstalling apps:
1. If in Windows - Start - Programs - Acer Empowering Technology - Acer E-recovery management -
click on Restore at bottom then "Reinstall apps and drivers" - look for hardware drivers that you
need. Click "install now"
Oct 05, 2007 | Acer 90.00012.30B Computer Speakers
1,842 people viewed this question
Top Acer Audio Players & Recorders Experts
Marvin
Marvin
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
