Question about SanDisk Sansa e200 MP3 Player
Sansa 280e broken screen
Hey, is there somewhere I can get a new faceplate/screen for the sansa 280e?
  • noemansland Feb 07, 2008
    My screen broke also player still works great I search for the faceplate or screen someone has got to sell it.
  • 8,596 Answers
No one sells it - you must replace the whole player
Posted on May 26, 2008
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
Can not get my sandisk 280e to reconize music on the device
unable to detect my sandisk sansa e280 mp3 player with my computer? What to do?
Jan 18, 2011 | SanDisk Sansa E280 MP3 Player
Transfered music see it on computer but not in the mp3 player
The songs are in the wrong format. Redownload them in mp3 format and all should be well.
-Tha Mp3 Doctor
Dec 23, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250R - Will pwr up but only freezes on screen that says..."Sansa Rhapsody"
instead of volume +, use REC - the correct button is located in the manual somewhere
Jul 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa clip 1 Gig
Sandisk website used to have the correct software, but they might have discontinued it - give them a call to be sure
Jul 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 280e mp3 player
Call technical suport at Sandisk. You might have a corrupt file. They will walk you through the steps. You may have to reformat which means you will lose everything you already loaded. I've had mine for about a year and it's still working fine. You may need to load the latest firmware as well.
May 31, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e250 cracked faceplate needs replacement
If it's just the faceplate (and not the underlying actual LCD) you could replace it with the intact faceplate from an otherwise defective unit. Any of the e200 series should fit. Try that online auction site to see if you can find a cheap defective one, just make sure the faceplate isn't cracked before you bid.
These mp3 players should *always* be placed in one of those clear protective cases. I have mine not only in a clear plastic case, but also in a leather case with a belt clip. Never just stick it in your pocket as that will surely lead to a damaged headphone jack.
Jan 04, 2008 | SanDisk Sansa e200 MP3 Player
Help my sansa is broken
i have the same problem....i am currently trying to get mine fixed. Sandisk told me to take a picture of the broken mp3 player and send it to rmaunderscoresupport@sandisk.com, i have sent it to them 8 times within the past 2 months and they still said they have not recieved it. let me know if you find anything out...
Jun 22, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 cracked screen
I've tried to get a replacement LCD for my SANSA, impossible so far.
There are some PARTS/REPAIR SANSA's on ebay, but must of them with the same problem. There was also a working LCD, I just fail on bidding.
If you can get a working LCD, the replacement is possible with a blower, directing heat to the specifyc connectors area, you can remove the broken one while the glue (some kind of silicon) is warm and flexible, you have to be careful when putting the new one, pins must be aligned, also you should do that whith both (broken and wkring) at the same time, so then you can use the glue still on the pins (golden connectors) area.
I got to remove the broken one and noticed (with my fingers) that the silicon can be used again, but since I didn't use a blower some of the pins (connectors) where damaged. Only halve of the process is confirmed.
Good luck, we'll wait 4 your results if you get a working LCD somewhere..
Nov 30, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
98 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
