Question about Toshiba A15-S1292 Notebook
DVD-ROM I have a Gateway MX3215 - As of recent my CD/DVD-rom is not recognizing when there is a cd/dvd in loaded. The light near the mouse pad blinks 6 times when loaded. The eject button also doesn't work, I get the same 6 blinks and it doesn't open. I have to use a paper clip to manually eject. The system says there is no problem. Do you have any ideas on what I can do?
    Novelist:
  • 188 Answers
Replace the drive - Those should not be too hard to replace - mOst of the newer gateways just have 2 screws on the bottom to remove the drive and it slides right out.
HEre is a link for the hardware guide for that model.
http://assets.gateway.com/s/Manuals/Mobile/8511189.pdf
Then look at the drive to get the model number. Search ebay or the internet for that model and you can get the proper replacement.
Posted on Dec 26, 2007
  • 383 Answers
LS-120 SuperDisk drive help The LS120 will not work off a sound card IDE channel. ... If the computer is on, however, does not eject and you are running Windows 9x.
CD-ROM tray not opening See document CH000885 for additional information about why the CD-ROM or other disc tray ejects by itself or does not close.
CD or other disc tray does not close or opens by itself.
Good Luck, read and folow instructions/Please dont for get to Vote/Thank You.
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Tip
Upgrade CD/DVD ROM to CD-RW/DVD ROM
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
on Apr 13, 2008 | Toshiba Satellite 1805-S253 Notebook
Cd is stuck in my gateway computer
If you open Computer in the Start Menu, right click on the DVD/CD Rom, select Eject , it still will not open? Look for a "pin-hole" on the DVD/CD drawer, near the button, insert a pager clip. If the CD has exploded, which happened to me, you will have to remove the DVD/CD Rom and dissemble it.
Mar 07, 2013 | Computers & Internet
Have a HP DVD 840d burner, my pc only recognizes the cd rom not the dvd burner. any help to get this to recognize my dvd burner.
If you load a commercially-produced DVD disk into the drive, does it show in "My Computer" or do you get an "insert disk" message?
If it shows, right-mouse click on the icon, and choose "Explore".
Does it show files/folders, or is there an error-message?
Oct 11, 2010 | HP Computers & Internet
Worked in other computer in this Gateway Celeron 1.2gh it does not recognize that it has a cd or dvd in it. Running WinXP Pro with sp2, roxio 9 and Cyberlink PowerDVD6
If the pc isn't recognizing the hardware the main reason this happens is that you need to install the proper drivers.
Here's a link: Hope it helps
http://www.opendrivers.com/category/15/cd-rom-free-driver-download.html
Good Luck =)
May 24, 2009 | CyberDrive DVD-ROM DM-166D Internal DVD...
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Jan 24, 2009 | Dell DVD-rom DVD Drive
Dvd rom automatically eject & loading frequemtly
I'm afraid when a drive starts to eject the draw especially on boot up, it's a sure sign that the unit is faulty and needs replacing.
Jul 11, 2007 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Toshiba A15-S1292 Notebook Logo
181 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
