Sounds like your problem may be with the heating coil. If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric. Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. Good Luck, Hope this helps
Was this helpful?
Yes
No
Popular Solutions for Kenmore 62802 Electric Dryer
I have to leave the door open to stop it. If it is something that is not disconnecting, I would be...
(More)
I have to leave the door open to stop it. If it is something that is not disconnecting, I would be happy to cut the buzzer out of the circuit completely. I have a separate timer that I can use instead. Sears said the part to fix it would be $110. Bought in 95 Model 85631.
I want to know which year it was made. It does not start at all and I was wondering whether it was...
(More)
I want to know which year it was made. It does not start at all and I was wondering whether it was worth repairing or to get a new one
I have same situation. Runs fine but does not heat. Yesterday, heated for first 10 minutes, then...
(More)
I have same situation. Runs fine but does not heat. Yesterday, heated for first 10 minutes, then door opened on its own (another problem). Started up again, but no heat after door opened. Next day, no heat. model number is 11072822101
Select a cycle and it lights up...then nothing but a clicking noise when you hit...
(More)
Select a cycle and it lights up...then nothing but a clicking noise when you hit start.............almost 6 yrs old
