Picture Shrinks to top right corner of screen - Vizio GV42L
Picture Shrinks to top right corner of screen when activating (then exiting from) the guide. If I activate the PIP option, the pip picture shows up in the top left and then fixes the problem (original picture expands to full screen)
  • Anonymous Jul 25, 2008
    yes, 1 week ago. comes, goes, but mostly a small ribbon of viewing across middle of tv screen ... ready to go buy new hdtv.
SOURCE: pip screen and tv screen wont produce a picture at the same time
Order a new TV....thats what I have to do. I have the Protron 42", and I cant get any sound, and I cant get the remote to work. Figures, too.....the TV JUST passed its warranty period by 4 days! I havent seen any positive things said about this company, either.
Posted on Nov 04, 2007
oicur12
  • 31 Answers
SOURCE: pip and pop
It sounds like your other TV had 2 tuners which allowed you to watch 2 programs at the same time. You can still watch two programs, but the second one will have to come from a second source. See below for the possible combinations that the PIP/POP feature can be used by this TV.
Posted on Feb 17, 2008
  • 92 Answers
SOURCE: not able to activate picture in picture
CHECK YOUR OWNERS MANUAL DEPENDING ON YOU MODEL AND THE TYPE OF CONNECTION(HDMIOR COMPONENT) IT MAY NOT BE AVAILIBLE WITH HI-DEF
Posted on Feb 22, 2008
Marrie
  • 563 Answers
SOURCE: pip position
Hi there
The PIP ( picture in picture ) is only to determine where the Menu block itself will show on your screen.
Try the Vertical and Horisontal shift in the Menu Options.
Posted on Apr 01, 2008
  • 21 Answers
SOURCE: LG HDTV large screen is blank but guide/list/pip shows up
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Posted on Apr 22, 2008
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
An object was thrown at one corner of the screen. When turned on it looks like a spider web and there is no picture. Can screen be replaced?
Yes, it can be replaced, but the price of it might approach the cost of buying a whole new tv. Get quotes and weigh your options. Good luck.
Nov 28, 2009 | Vizio GV42L 42 in. LCD Television
Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at kmarlin@grandvalleygolfclub.com. thanks, keith
Jun 27, 2009 | Vizio GV42L 42 in. LCD Television
Have a one foot by one foot black box in lower right corner of tv.
thats called PIP aka picture in picture on your remote theres a way to turn it off or change the chanel of it what it is its like another tv but with no sound and you see another chanel or video input on it and you can switch it on the remote
Mar 27, 2009 | Vizio GV42L 42 in. LCD Television
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
Thin white static line at top of screen for some channels vizio 42 lcd hdtv
i had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
Mar 13, 2009 | Vizio GV42L 42 in. LCD Television
Multiple problems with Vizio Galevia GV42L
I have the same problem and it is just livable.  Turn on/off a couple of times and it will be OK.  Interestingly, The Samsung 40" LCD has a powersupply (bad capacitor) problem that seems to mimick this problem  There is a huge thread elsewhere on this Samsung issue, do a search.  Let me know if there is an explicit solution for this.
Nov 14, 2008 | Vizio GV42L 42 in. LCD Television
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
263 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
