Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My HDTV breaks into pixels. How can I prevent this?
Picture pixelation- with xbr5 bravia and comcast HDTV MOTOROLA CABLE BOX. I suspect that the cable signal is not very good and might need a boost. I have all the correct cables with tight connections. What is the solution? Comcast will not help me.
I have occasionally faced same pixel problem with xbr5. Connect the RF cable directly to your TV and tune it to same channel to verify if the problem is in TV. Most likely you will get better picture quality.
Posted on Jul 21, 2009
From what I heard, comcast is sending is compressed video signal. I also witnessed this on a xbr5 at someones home. Its not your tv from what I've heard its your provider trying to keep up with demand. I hope that helped.
Posted on Jan 04, 2008
We have Comcast cable and are experiencing pixelation problems. This only happens between 9 a.m. and about 6:30 p.m. This happens on both an HDTV and an analog TV. Both TVs have cable boxes as well as...
Entre em contato com a sua operadora de tv a cabo. Isto e muito comum quando o sinal e trocado de analogico para digital. O problema e da operadora.
Dec 13, 2010 | Vizio P42HD Television
Pixellation on most channels
The pixellation on cable channels usually indicating poor/weak cable signal. You may want to have the cable signal strength check out by the cable company, check your cable connection at the entrance of the house to make sure they are clean and tight, try connect and disconnecting them. You are not the cable company cable box are you? My had to be replaced twice by Comcast, they were running very hot.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
The color red is starting to flow throughout the picture.
I have fixed a lot of Vizio TVs. You are getting red pixelation. Some people have green pixelation, too. Usually change main board and main connector cord for fix. Check with vizio and see if it is still under warranty. Some parts have a lifetime warranty. If you call support and give them your model number they may be aware of the problem. It is not your inputs or wiring. It is the boards inside the TV. Let me know how it turns out. Good luck, John.
Apr 08, 2009 | Vizio VO47L 47 in. LCD TV
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
Pixelation
This model has been known for problems with the Hyper module but the picture would be affected with any input source.HD or not.The cable converter box and the cable signal are the only culprits for pixilation.Pixalation is the result of missing digital information via signal.If it is only appears on the HD signal I would suspect the cable signal or the converter box.I assume you are using your component input on your TV or the HDMI input.As a technician I would suspect the cable box or cable for pixalation.
Jan 19, 2009 | Toshiba 46H84 46" Rear Projection...
Image gets pixelated and a black screen flashes
yes its a cable box problem, find the channel you are having more problems with,press guide in the cable box remote and you will see how the box where the video is will still have the problem and the guide with channels info its going to be clean,
100% weak signal
hdtvman
Jun 22, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
SONY 52" XBR5 Screen Damage
You are correct, the screen is damaged and in most cases cost mre than a replacement tv. There is no repairing a damaged LCD panel, just replacing.
Jan 31, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia KDL-46S2010
Try plugging the coax directly into the T.V. or from you VCR or DVD player then to the TV. The bravia sets also have various picture mode settings as you will discover when you go through your manual. Cable boxes or splitters can cause problems also is they are not of good quality. I love my 40.
Jul 13, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
715 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
