Question about Linksys Wireless-G WRT54GS Router (e125894)
Wireless laptop my wireless laptop has a padlock on it's linksys connection, how do I get it off so I can use my computer? Thanks
  • hudmel Feb 10, 2009
    Linksys WRT610N
    Trying to connect Ipod Itouch---Padlock on WiFi connection--can't connect
  • 62 Answers
If you are viewing "available wireless networks" and the one you want to connect to has a padlock on it then you should have an encryption key that should allow you to connect.
If you do not have the encryption key then you will need to reset your router to it's "out of the box" state.
You can do this by pressing the small reset button on the back of the router for 30 seconds.
Remember when you do this all of the routers configuration settings will be set back to the default. This means that the name of your wireless network will change back to "linksys". Also resetting the box can cause a conflict with certain DSL modems that assign IP addresses from the same subnet as your router.
Posted on Dec 26, 2007
Asus K501 laptop - what is the 2nd light with a number 1 in a padlock. This is between the Wireless and Caps lock leds. Laptop will not connect with wireless, ok wired. thanks
The number 1, in a padlock, means "Number Lock". If your computer has a numberpad, this is fine. If it doesn't, it means that the letter keys to the right will act as numbers (often printed on the keytop in a blue colour).
Jul 23, 2011 | ASUS K50IJ-C1 Notebook
I recently bought a linksys wireless router i've
Make sure your wireless feature is turned on on the computer. There may be a switch on the edge of the computer somewhere, you don't say what kind of computer it is.
Find the wireless connection wizard on your computer and run it. Find it in your network folder in the control panel.
If this is too much, post a comment to this question and we will back up and start over.
BTW, if your laptop has a ethernet outlet (looks like a big phone jack), you can wire your laptop to your router.
I want to help you with this problem
thanks
Dec 08, 2009 | Linksys Wireless-G Broadband Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G can't connect 3rd wireless computer
log into the WRT54G wireless router and ensure that you do not have it set up for only handing out 4 IP addresses also check the laptop to see if it is set to have a DHCP or static IP address, if it has a static IP and your network is dynamic then this is why it wont connect.
if this resolves your issue and you are happy with the answer please grade me accordingly.
thanks
Aug 25, 2009 | Linksys Wireless-G WRT54GS Router...
Slow wireless internet connection for select PC's; fast for other
Make sure that your wireless mode is set to "mixed mode".
Intermittent Connectivity:
NOTE:
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 20, 2009 | Linksys Wireless-N WRT150N Router
Linksys Wireless B Router Compatible with Windows Vista?
I would advise you to purchase a Linksys G router, Model # WRT54G2. Works well with Vista and your other laptops will work also.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 26, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Wireless computer and home computer
Make sure that the modem is plugged in to the wireless linksys router. Plug in your desktop to the ethernet port of the router and check if you're able to get online. If you have a cable or dsl connection, make sure that your router is already configured to work with the modem. Your laptop should automatically detect the wireless network. Scan your wireless network by right clicking the wireless network icon and click on view available wireless networks. The default name of the linksys router is linksys. Try to connect and see if you're able to get online.
Feb 08, 2009 | Computers & Internet
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Can not connect adapter to laptop no installation CD-Rom
you have to install the driver for it to work and i assume that is not the case as you have no cd. Go here to download the driver. http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1134691790190&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0993490190B03 When installed go to the properties of your adapter in network connections, then click on tcp/ip line and then properties and ensure obtain ip address automatically is ticked and press ok. You may also have to use the home network connection wizard if you havent previously to share documents over your network.
Apr 13, 2007 | Linksys Wireless-G WUSB54G 802.11g/b
Linksys Wireless-G WRT54GS Router (e125894) Logo
47 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
