Question about Toshiba SD-4700 DVD Player
Toshiba SD-K760SU The DVD player does not seem to recognize DVDs.  The word "No" appears on the readout sreen on the player.  It also says "Not allowed at this moment>" It either seems to think there is no DVD in the machine or it says< Is is not the parental limits as those are set to Adult.  I have tried various DVDs How would you fix this?
Re: Toshiba SD-K760SU
I found that the ribbon cable from the DVD tray to circuit board located in the middle of the chassis was loose. It only seems to be wedged into place. I inserted the cable back in and made sure it was wedged into place securely. I have had to do this twice now.
Posted on Aug 18, 2008
0 characters
3 Points
Why does atr appear on vcr sreen
Borrowed from Toshiba's site: Unfortunately this unit was meant to record from DVD to VCR and not VCR to DVD. The DVD section of this unit is a Player only and does not record. I was not able to find an "atr" function on the unit. If you meant OTR that stand for "One Touch Recording."
Jun 12, 2014 | Toshiba SD-V290 DVD Player/VCR
Will not play all DVD's
Try a dvd lens cleaning kit. This may help.
It could also be the laser itself. Newer DVDs require a very strong laser to read them.Older ones do not.
You can pick up a cleaning kit at Wal mart for about 10 dollars.Hope this helps
Sep 18, 2009 | Toshiba SD-4700 DVD Player
Erratic operation of DVD players after a few months of non-use
what you should do is to clean the OPTICAL LENS directly with a dry Q-tip , could be that it collected some dust and thats why its playing erratically, give it a try , AJ
May 29, 2009 | Toshiba SD-1800 DVD Player
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
the sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
May 07, 2009 | DVD & Blu-Ray Players
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Feb 04, 2009 | Toshiba SD-3990 DVD Player
Dvds wont play
Check out the link I have posted below.
according to the list, your in the 5% area of dvd players that won't read burned home made disks-DVD's
Sorry Pal your in the same boat as myself.
I have a Toshiba SD-2107 --- We're both aout of Luck :(
Looks like it's time to invest in a new DVD player.
Aug 05, 2008 | Toshiba SD-2109 DVD Player
New DVDs won't play
What studio label? Some Newline DVDs appear to have some new protection, newer than the Sony ArcOS protection (or whatever it is called).
Jan 18, 2008 | Toshiba SD-2700 DVD Player
Can only play DVDs for one region code.
Most DVDs can only play DVDs from a single region. However, they sometimes allow you to change the region at least one time. Another option is to make your DVD player region free. This is a hack that can be performed. Once you do this, you can play DVDs from any region.
Please see the following link for more information:
Jan 17, 2008 | Toshiba SD-K760 DVD Player
Toshiba SD-K760 region codes.
I found this on another site, worked for me, hope it helps...
icon_minipost.gifRegion code hack posted by Stratos, April 30 2006:
1. Press the Open button on your remote control to open the drive tray
2. Press the 2403960 button on your remote control
3. Press the 1 button on your remote control to change the region to 1, 2 for region 2, and so on, or 9 for multi-region playback. New region number will appear on screen.
4. Press the Open button on your remote control to close the drive tray
5. Power off the DVD player
6. Power on the DVD player
Toshiba SD-4700 DVD Player Logo
601 people viewed this question
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
