HP LaserJet 4 plus Printer Logo
Anonymous Posted on Oct 11, 2009
After turning on printer, prints initial "blank" sheet
Whenever I turn on the printer and immediately print, the initial sheet is blank except for "s1M" printed in the top left hand corner. How do I stop it from wasting paper. I have an HP LaserJet 4P.
Thank you.
Anonymous
Level 3:
President:
  • Master 2,049 Answers
  • Posted on Oct 11, 2009
Anonymous
Master
Level 3:
President:
Answers
2049
Questions
0
Helped
1489573
Points
8420
You can fix this by turning off bidirectional support:
- Right click your printer, select properties
- go to the ports tab, uncheck Enable bidirectional support.
Your printer has to be turned on before printing.
That fixed the extra page printing S1M problem for me.
Testimonial: "Solution worked great and will save future trees by not wasting paper! Thanks for the help."
  • Celeste27 Nov 12, 2010
    Thank you so much!!!! This has been driving me crazy for months. I wish I had come here sooner.
  • Anonymous Jul 30, 2012
    This also worked for me, thanks for the tip.
Robin greene
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 17 Answers
  • Posted on Sep 17, 2019
Robin greene
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
17
Questions
Helped
12222
Points
64
Sometimes the error of "Printer Printing Blank sheet" There are some common reason behind this error:-
  • The problem can occur if the pages you are using for printing requires more ink than the standard metric.
  • Clogged nozzles in the printhead can be responsible for the low yield of cartridges. Epson printer has reduced the diameter of the nozzle for enhancing the printing quality. The small diameter leads to a clog easily.
  • The problem can arise if you are not using original Equipment Manufacturer's cartridges. A third-party seller will not give you genuine cartridges.
  • If you have not cleaned your printer for an extended period, dust accumulates inside the printer and restrict your printer to print properly.
  • When you do not use your printer regularly, then ink in the cartridges will either dry up or clog in the printhead.
There are some steps to fix this issue, and the whole solution can't be posted here, so I am pasting a link below. Just do visit on the link.
RESOLVE THE ISSUE
Click on the link below:-
https://www.hpsupport365.com/blog/fix-hp-printer-printing-blank-pages/
2helpful
Cannot print pdf file on x1270
If all else prints fine except when printing PDF files, try to update your Adobe Acrobat. Then, after the update is successful, try to print your PDF file again to verify that the problem is fixed.
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Alignment/selftest sheets print whenever I turn on the printer.
its up to you if you want to make self test..but you can cancelled it if you dont want to make self test..
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Printing labels
You have to feed the labels through the manual feeder.
1helpful
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Printing issue..please help
That sounds like a banner sheet, in your menus, Specifically a print menu you will find a section with reports, it should be caled banner sheet.
They may have another name for it. But disable that. Also go ont the driver on your computer and look to turn the banner sheet off.
Some call it a print acrivity sheet also.
make sure those pages are turned off on both the printer and on the print driver on the computer.
k24674
Grand Canyon Tech
Grand Canyon Tech
