You must logon to the router (generally browse to 192.168.1.1 - depending on model).
Go to the [Security] tab and add or change the code(s).
You can set several WPA or WEP codes and enable/disable as needed.
Always have code#1 enabled for yourself.
Enable code#2 whenever you have friends over and disable it when they are no longer there. They don't know code#1....
- Locate the reset button of the router - Hold down the reset button for 10 secs. while the router is on. - Unplug the power adapter from the wall socket while still holding down the reset button for another 10 secs. - Then, put the power back on.
This should be enough to reset the router. You may now reconfigure the router with a new WPA key.
Please refer to the user manual or contact the tech support of the router if you are having a problem reconfiguring the router.
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
using SMC SMCWBR14-G2 wireless router tried to configure router but it says it cant perform any...
(More)
using SMC SMCWBR14-G2 wireless router tried to configure router but it says it cant perform any operation with out the media being hooked up. All cables and internet acess is hooked up. Is my router shot??
How do I stop my NETGEAR WPN824v2 Wireless Router from loading at startup? Running Windows XP svc...
(More)
How do I stop my NETGEAR WPN824v2 Wireless Router from loading at startup? Running Windows XP svc pack #3
I put in a router and the main computor works find . the other computer says it cant find the...
(More)
I put in a router and the main computor works find . the other computer says it cant find the internet and something about a modem cable for that computor.
