Home | GE | 46GW945 46 in. Rear Projection Television | Tv turns off imm...
GE 46GW945 46 in. Rear Projection Television
Problem for GE 46GW945 46 in. Rear Projection Television
Tv turns off immediately after i try to turn it on
By ralphadordor on Oct 11, 2009
i have a 50 inch GE tv about 10 years old. when i try to turn it on it makes the sound as if it is going to turn on but immediately turns off an then it tries to turn its self on
Best Solution
posted on Oct 11, 2009
Very Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 854 votes
I know this set--worked on a lot of them when they were first new---THE MOST COMMON PROBLEM is the high voltage transformer fails--usually a dead set.
As you look from the back of the set it is a tan colored part about the size of your fist (located to the right side of the board on the far left--it has a large red wire coming out of the top of it)--if you hear a squeeking noise or not--it is the most common part to fail in this set.....RCA PART NUMBER IS : 239111---PART is no longer available from RCA but if you Google it on the internet---there are several places that have a replacement part for less than 15 dollars---
The way I used to attack this was to unsolder the transformer and try to turn set on--if it comes on it will not have a picture but if it does not shut down--you know either the transformer is bad or something right around it---note---I have seen over 100 of these sets with this part bad--number one part to fail in this set.
Let me know if you need any help or assistance.
Regards, SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE 46GW945 46 in. Rear
Questions and Unsolved Problems for GE 46GW945 46 in. Rear
Do you recommend GE 46GW945 46 in. Rear Projection Television?
Answer
Answer
Hi! the picture has dropped about 6 inches and the green control does not go up also the picture... (More)
Answer
GE 46gw945 52" Just moved from one house to another, tv was wrped in blankets and wraped in... (More)
Answer
I have Dish network and after they readjusted my dish the universal remote did not control the GE... (More)
Answer
the picture is distorted. the color is splitting from the image. red, green blue yellow is... (More)
Answer
posted by luckey777 on Apr 16, 2009 i have this model GE 46" projection tv that does not power... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE 46GW945 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
