Question about Frigidaire FMV156D Microwave Oven
Smeg microwave - SA-31MX
Everything is working fine but suddenly it will not heat up anything Thank you Mark
  • 3037 Answers
SOURCE: Microwave doesn't heat anything
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Posted on Apr 26, 2009
0 characters
1 Points
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
Microwave not heating anything? everything else work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Jul 28, 2010 | LG LMH1517 1000 Watts Convection /...
Does not heat food.
Dont have many smegs where i am, but smeg is a decent unit, so i would think if there is no heat, look for a reset button (over temp. protection). possibly located at the back where the elements are wired.
Sep 15, 2009 | Microwave Ovens
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Smeg Microwave SA-971C2
the door protection circuit needs attention, the door catches operate microswitches, but there is also a third which is a crowbar microswitch. if all three do not operate in the correct sequence then the safety switch or fuse will go.
Feb 18, 2009 | Smeg FMC24 850 Watts Convection /...
Smeg microwave SA 31MX not heating is it repairable and at what cost and where at we live in werribee victoria
it is repairable, the problem is the magnetron needs to be replced ( an element that emits the micro waves ) but will need to be checked to make sure its not the capacitor that starts it or the circut that controls it.
repair shops vary so ask them about how much they would charge to replace the magnetron then you will be able to tell who will end up charging you the most and who would be cheeper(aprox $50-$75 plus parts
Oct 15, 2008 | Smeg Microwave Ovens
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Frigidaire FMV156D Microwave Oven Logo
74 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
