Question about SanDisk Sansa MP3 Player
"No song" bug
Hi. I have a Sansa Express 2GB with a 2GB Kingston Micro SD card.
I think the bug I encountered is quite rare, but serious. I found only a few posts about it in the web, but none with a working solution.
Descripiton of the problem:
When I try to play songs by going Music->Artists->[artist], very often (I'd say 2/3 of my songs) I get a "No song" message. When I go through Music->Play all, all the songs are played correctly.
Also, it's impossible to play the songs in Winamp directly from the player, and Winamp crashes instantly after plugging the player in, and won't open as long as it's connected. Though I don't know if any the problems are connected. Of course the one with the "No song" message is the only serious one.
What I've tried:
- I've tried (of course) formatting the player, both using itself and using windows.
- I've tried resetting the settings.
- I've tried messing with ID3 tags, removing them, adding, trying only with a 1.1 tag, only with a 2.x tag. When compared to a different file that plays correctly no apparent differences in tagging can be found.
- I've tried moving the file, and a strange thing happens. Randomly the file after being moved (like from the Music folder up to the main catalogue or to a new folder) behaves normally or shows the "No song" message. I've tried having two files on the player and moving them around folders (including the SD card), and their behaviour concerning the bug is completely random.
- The firmware is up to date, but I don't know if the bug occured before updating it - it was the first thing I did after getting it yesterday.
- I've tried removing the SD card, formatting the internal memory and putting some songs in - same thing happens.
This bug really kills much of the player's funcionality (can't browse artists). Please help!
  • 26 Answers
Re: "No song" bug
Are these MP3s VBR or fixed speed? -- And does this problem also happen with WMA's? I guess I would try different speed (128/160 BPS) type MP3 and also WMA. I would venture the problem is PROBABLY in the mp3 files. (Mostly because Winamp can't seem to play them either.)
Posted on Jan 07, 2008
0 characters
3 Points
Sansa c240 (1GB) MP3 Player: i have a sandisk sansa c240 and a 2gb micro sd car...
You Can Download Free MP3 From Youtube By This Site :
If you didn't found Your Favorite Music In Youtube Try These Sites : or
May 17, 2010 | SanDisk Sansa c240 MP3 Player
My sansa express dosnt know it has a micro sd card full of music in it. please reply to:
Early versions of the Sansa express will not support High Density microSDHD cards whcih are usually found in Cards greater than 2GB and definetely on cards greater than 4GB.
In Flash drive mode, make sure that the microSD card can be seen on your PC as a second drive for your Player. To ensure better compatibilty, I would suggest that the microSD card be FORMATted while inserted in your Player.
I would initially only put a couple of songs on your microSD card to test that the card is compatible.
Dec 22, 2009 | SanDisk Sansa MP3 Player
2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
Aug 27, 2009 | SanDisk Sansa Fuze MP3 Player
I need to know the maximum GB external micro sd card I can put in a sansa E260 4 GB Mp3 player and a sansa express 1gb mp3 Player.
thank you for choosing
you can use 4GB it is the applicable memory on your mp3.
if you will try to use much higher than 4gb sometimes it is the reason why our player are hanging up.
please don't forget to rate our answers properly.
Mar 05, 2009 | SanDisk Sansa e260 MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
My Sansa WONT read my micro and wont upload songs
You should try to copy your music/files to your computer and format your SD Card. After that, copy your music/files back to the SD Card.
Feb 09, 2009 | SanDisk Sansa e200 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
89 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
