Question about American Audio DCD-PRO310
Problem finding tracks
I have HP 48X 80min cd-r's burned on an external Sony drive. Some of the cd's work ok, some have problem finding tracks. Once a track is found, the cd plays perfect. Sometimes the unit never finds the selected track. I have 2 units, two of the players have some problems finding tracks.
Try bunring a cd at the slowest possible speed and see if it helps. Also I would try a different burning software than what you are using now. (Even if it is iTunes or Media Player and if your already using these try roxio or nero instead).
Posted on Apr 02, 2008
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
How to format a CD-r disc
Can not format a CD-R disc, only CD-RW are rewritable.
Sep 04, 2012 | Sony CD-R Discs - 700MB/80min, 48x,...
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
How do i get the track list form my cd's so it does come up with the track list no tack1, track2 so on... i have on a hard-drive, so i don't have to keep wighting the track list one buy one
Nearly all CD burning/ripping software can use this or another online CD database, like CDDB for example. You have to turn on this functionality.
It will work for most popular CDs, but some rare or obscure artists still will not be found, and you'll have to be writing the track list one by one.
Nov 12, 2009 | Dell Computers & Internet
Tracks too short to to create CD from hard drive.
either have to delete the short tracks from playlist to burn...when i get mssg theres usually nothing there (hit new track 2x by accident, just silence) Or if u want what is on the short tracks, have to join it to longer track b4 or after it, making one longer track, and no more 1 sec track...to do: hold playlist edit and delete track button, will ask if want to join two tracks, say yes and its done...When u do this, the track you do this on will b joined to the previous track, it will give u mssg showing which two tracks about to join and what track name will b left...(for example do u want to join track 01 to track 02...resulting track name will b track 02)..can then burn once all short tracks either deleted or joined to larger tracks...
Apr 03, 2009 | Alesis MasterLink ML-9600
Downloading my music and then burning to a cd
Have you read the section of manual relating to 'Importing CDs' ?
Select a playlist, press 'playlist edit' - press HD/CD - insert CD, close drawer. Once Alesis has scanned disc, press 'track move' - display should read Move CDTrk -> Trknn where 'nn' is the next available track in playlist. Press Cursor Left to place cursor under CDTrk, press Down/No, and display should read Move CD->Playlist. If you now hit Yes it will copy all CD tracks to the active playlist (it'll prompt if the playlist isn#'t empty to make sure you want to add the CD to the tracks already in the playlist).
Once they are copied to the playlist, you can move them around if required, DSP them, then burn that playlist to a blank CD
Dec 02, 2008 | Alesis MasterLink ML-9600
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Jumping Tracks when using "Next" control
    find the "reset" button (this button usual is very small) find it in front of the control panel, if the control panel is removable find "reset" button after removed
    Feb 02, 2007 | Sony CDX-T69 6-Disc CD Changer
    American Audio DCD-PRO310 Logo
    77 people viewed this question
    Top American Audio Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Gil Shultz
    Are you an American Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
