Question about Nikon D70s Digital Camera
Nikon D70 - indoor flash problems
I've had good results with my D70 with outdoor photos for the past 2 years. Indoor flash photos on all settings are very, very underexposed. The flash is going off - I've tried Aperature settings, Auto settings, nothing seems to work. I reset the factory setting but that did not seem to help.
  • Mojave Dec 26, 2007
    Thanks. I'll give that a go. Joe
  • 667 Answers
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Posted on Dec 26, 2007
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
When taking indoor photos, sometimes i get shadows on different placesof the photo
If you're getting shadows on the bottom center of indoor photos when take with a flash, it is most probably due to the length of the lens on the camera.
A long, telephoto / zoom lenses will create the largest amount of shadow, while shorter and wide angle lenses will be least likely cast shadows. You can reduce the amount of shadow in pictures by removing the lens hood that may be on the end of the lens. The lens hood is to primarily to shield the lens from direct (sun) light, and probably isn't needed for indoor flash photography. Also, rely less on the zoom function of the lens on the camera and physically moving closer to your subject instead. The flash will need to provide much less light output and result in more flashes per battery.
You could use a separate flash - held off the camera so that the lens is not obstructing the light of the on camera flash. Using a Nikon Speed Light, you can set the on camera flash to provide a low output, that would be used primarily to trigger a Nikon Speed Light held by someone or arranged on another surface etc. Youtube is a great source for real life, practical "How To" videos for many operations of the camera and accessories.
I hope this was helpful!
Oct 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Z740 cannot focus on long-distance indoor shots
Have you tried changing the mode? ie portrait, closeup, macro etc?
Jun 19, 2009 | Kodak EasyShare Z740 Digital Camera
System will not start up.
This is a signal fault between the indoor and outdoor first make sure the dip switches are set start with the unit closest to the condensor set as unit 1 then next unit as 2 and so on the dip switches are inside the indoor unit on the pc board if you check the manual it will tell you which swithes to set, if this wasnt done when the units where installed they would have never worked i would also check the signal wiring between the wallmount and the splitter box / bc box and make sure there isnt a loose connection when you have ruled this out id say more than likely it is a faulty indoor board on the wallmounted unt
Jan 27, 2009 | Fujitsu 24C1 Air Conditioner
Digital Camera with... Problem
You should set the white balance to an appropriate setting. For outdoors, or indoors with flash, auto +-0 should be adequate. For indoor work without flash, try the incandescent (light bulb symbol) or fluorescent (strip light symbol) if you don't like the results from auto.
Nov 17, 2007 | Nikon D200 Digital Camera with 18-200mm...
NIKON D70
The higher the ISO setting the more grain in the photo. Have you somehow set the ISO to say, 1600? http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b11&num=12 Select ISO setting this way: http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b05&num=10 Are you shooting in low-light situations (typically indoor)? Try shooting bright scenes and Auto mode, or manually set ISO to 100 or 200 and see if noise persists.
Apr 02, 2007 | Nikon D70s Digital Camera
Photos coming out with too much yellow
You're shooting under incandescent light, and the camera doesn't manage to set the white balance entirely automatically. You can try to explicitly set the white balance to incandescent, or you may be able to create a custom white balance (I'm not sure whether Nikon bodies offer that feature), or you can adjust the white balance during processing (in which case it's better to shoot raw).
Sep 14, 2005 | Nikon D70 Digital Camera with 19-35mm Lens
Sep 14, 2005 | Nikon D70 Digital Camera with 18-70mm Lens
Sep 14, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D70s Digital Camera Logo
179 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
