Question about Jwin JK-777 Nostalgic Stereo System with Turntable, CD Changer, Cassette Deck, and AM/FM Tuner Shelf System
Fisher CD player does not work
I have a Fisher Rack stereo system and the Studio 23 CD suddenly stopped working. When turned on, it goes through its start-up mode and searches for a CD then dispays an erroe message, "Error M" and won't work. Any suggestions will be appreciated. I have turened it off and on again and again, and changed to CD from the Amplifier, to tape, to Tuner, and back to CD, to no avail. My e-mail address is Thank you and Happy New Year.
2 Suggested Answers
SOURCE: Kenwood XD 550 stereo start-up problem
this normally happens with a lot of sets! It usually happens during a Power Failure, Power Surge (Fluctuation) and if the wire of the component is taken out from the wall outlet while the system is on...To get rid of this problem all you need to do is to press the Display button on the main unit, it is located just below the main display! Voltage Selection has got nothing to do with this problem...
Posted on Sep 05, 2008
SOURCE: i cant find the operators manual for Panasonic audio rack system
That hifi is not an old model,it was made in 2005,try contacting the head panasonic office in japan,they may help you
Posted on Sep 20, 2011
0 characters
1 Points
CD player works but start delays from 5 minutes to 20 minutes. What could cause that?
Dust inside the cd player could be causing problems.
You need to try playing a cleaning cd and follow the instructions that come with it. You can also spray compressed air to clean out the cd portion of the stereo. You can also try unplugging the unit for 20 minutes and then plug it back in. Make sure your cds are clean and not too scratched up. If the unit is under a year old it may still be under warranty. If this does not resolve the issue you may have to have the unit professionally repaired. If the unit is not worth repairing you may need to buy another unit.
Nov 02, 2015 | JVC UX-T3 Shelf System
No power, nothing at all
The best I can suggest you do is visit the Fisher website to see if you can get the user manual. Many have sites have free PDF's of them. If you can't find it send them an e-mail asking for the manual or where you can get one. That should tell how it operates and what the power cord should be.
But I would be surprised if it works OK.
May 11, 2013 | Fisher SLIM-1500 CD Shelf System
Unit does not turn on or display time
do you mean a power surge, if so the surge may have overloaded the elctronics,=cooked ,so afraid is u/s
Jul 07, 2010 | Fisher SLIM-3010 Shelf System
Disc will not eject nor play on fisher studio 24 management system. It holds 24 cds. My husband is furious, says I loaded cds backwards. PLEASE give any possible solutions. Thanks. Tina Georgia
remove the screws to your cd player and take this apart and remove the disk by hand and put system back together. It should work after that. I am a former tv technician. just be careful how you take it apart to put it back together again. do not plug unit in untill it's all done to avoid eye damage from the UV rays.
Feb 24, 2009 | Fisher Audio Shelf Systems
Fisher 143a CD Changer
You wont be able to play any new format CDs on an old Fisher or any other older make . It 's the internal decoder logic that's needed. And older players dont have it.
As far as top-loaders..Do a websearch . I dont know of any.
Jan 27, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Cd player
i need part # 6142539071 for fisher tad 993
Jul 09, 2008 | Audio Shelf Systems
Fisher TAD-5024
Mar 15, 2008 | Audio Shelf Systems
Shelf stereo turns off by itself and stops working all together.
how loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Feb 04, 2008 | Philips FW930R Shelf System
CD player stops, won't open
you have to unscrew the case. then you can get the cds out
Jul 16, 2007 | Emerson MS9700 CD Shelf System
Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Mar 19, 2007 | Fisher 9925 Shelf System
Jwin JK-777 Nostalgic Stereo System with Turntable, CD Changer, Cassette Deck, and AM/FM Tuner Shelf System Logo
305 people viewed this question
Top Jwin Audio Shelf Systems Experts
Are you a Jwin Audio Shelf System Expert? Answer questions, earn points and help others
