Standard Televisions
Problem for Sony Standard Televisions
Generic problem for all Sony Standard Televisions
Sony Wega FD Triniton KD27FS170 Does not...
By gatex3 on Oct 10, 2009
Sony Wega FD Triniton KD27FS170 Does not Start- Red Light Flashing I disconnected from Ac Power and reconnected and will not Start
Solution #1
posted on Oct 11, 2009
Not Rated)
jerryg50
Rank: Wiz
Rating: 84%, 887 votes
The most common fault with this model is the flyback transformer assembly is defective. Along with this, the horizontal output transistor may have also failed. In some cases this failure occurs because there is a drive problem coming from the horizontal scan driver circuit that is ahead of the horizontal output circuits. There may also be some support components that triggered the fault in the first place and would also be required to be replaced. When there is this type of failure, it is possible that the power supply may also need some service.
On more rare occasions, there may be a simple failure from the main power supply buss, or a failure in some other circuit that is putting the power supply in to protect mode.
An experienced TV tech who knows your model of Sony set can troubleshoot it and determine the exact failures. He can then give you an estimate.
This model of CRT set was considered to be an excellent TV set. Unfortunately when the full digital service is established as the standard, and the analog service is discontinued, you will require a digital to analog conversion box for this set to work with TV stations. Some cable TV and satellite TV companies will be supplying the analog signal in their standard package.
Jerry G.
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
have a 44 inch jvc - all the sudden squiggle lines at the top for about 10 inches. any ideas
Answer
I have a Panasonic TX 36PF10F CRT, which has always worked without any problems. When I press the... (More)
Answer
remote is not working for hello kitty tv need to know if theres a code
Answer
Right side of screen has a faint yellow patch surrounded by a border but can still see the picture... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Standard Televisions:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
Sony
(21591) 042-9690
Sony
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
