Hobart D300-6036 Mixer Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have a commercial dough mixer,
Hello, I have a commercial dough mixer, "General" brand. This unit has a power output hub that allows the use of slicers, grinders, etc. I don't know how to define the size or compatability of the hub. My unit receives a spud approx. 1 1/2 inch in diameter, approx. 3" long, with a through shaft having an approx. 3/4" square drive at the end. Can you tell me what might be compatable with, and is this a common drive system? Thanks. Jerry
Peter Hampton
Level 2:
Habit-Forming:
  • Expert 193 Answers
  • Posted on Apr 24, 2010
Peter Hampton
Expert
Level 2:
Habit-Forming:
Answers
193
Questions
0
Helped
79348
Points
348
It's a standard drive system found on most hobart mixers like the a200 style and you may find only hobart parts will fit it
I need parts to a Wolfgang Puck Stand Mixer. Dough Hook, Bubble Wisk, splash guard
Hello
We are a leading metal casting and cnc machining precision parts manufacturer in China.
Pls check our website to learn more about our products.
If you have a PDF or STP dwgs, pls send us so that we can quote for you immediately
You will get the most super quality and the most competitive price from us
If you let us work for you
Beat Regards ,
Simon sun
Ningbo Huayuan Precision Casting Machining Co.,Ltd
Ningbo Huayuan Casting Machinery Factory
Tel:+86-574-88166711
Fax:+86-574-88166721
E-mail:[email protected]
Web:www.huayuan-machinery.com
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Cant releace the dough hook from my kenwood chef. what can i do?
hi the lock nut on the shaft may have been loose allowing the shaft to screw into the dough hook you hve to unscrew the hook out of the shaft then unwind the nut down so you can release the shaft. other problems can occur if the retaining clip has unseated and jammed itself into the planet hub. this is more difficult and a kenwood agent would be consulted see www.kenwood.co.uk for nearest agent.
2helpful
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
1helpful
2answers
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
If this solution has assisted you, please rate it. Good luck! ricardok45
The ball turns in opposite direction.
You have a 3 phase unit, it can run opposite direction if the main feed wires are not correct for the motor wiring. If you simply swap any two of the main electrical feed wires it will run in the opposite direction. This should correct your problem now. Enjoy.
1helpful
2answers
MIX7130
ship it back to anvil , buy a hobart ,best mixers in the world
Hobart N50 Tripped
The reset button is to protect over amping the motor. The N-50 is not a very strong unit, (commercially), but you won't break a gear. If you overload the unit, you'll either trip the overload (reset button), or you will break the taper pin that attaches the planetary to the center shaft.
If you're looking for a small commercial unit, and you're in the US, look into the 10 qt Precision Mixer.
Metal stem broke!
you should be able to order the part from kitchenaid.com. while you replace the stem it might be a good idea to replace the hub, and the gear assembly in the planitary unit
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
